1 FS: Additional Instruments Mon 30 Oct 2023, 12:08
It's an almost complete kit including:
- temperature gauge
- fuel gauge
- plastic cups and thumbscrews for fairing mounting in the RT speaker positions or LT inner fairing knee pads
- auxiliary wiring loom from the additional instruments connector in the main loom to the gauges (only really long enough for the LT without being extended). The PVC sleeving feels a bit stiff and may be prone to cracking if mishandled
- temperature sensor for the blanking plug next to the oil pressure switch under the water/oil pump. It's not tested, but looking at the condition and knowing me it's probably new
What's not in there:
- the black wire from the temperature sensor to the blue connector on the auxiliary loom
- the rubber cover for the temperature sensor (same as the oil pressure switch)
- both are available from Motorworks
It cost me £80 from ebay, so I'll take that. P&P included for the UK, but overseas at cost. I'll add pics tomorrow because it's pissing down with rain and I can't be a$$ed to go back out in the garage tonight.
- temperature gauge
- fuel gauge
