1 top bolt RT upper fairing bracket Mon Oct 16, 2023 8:10 am
tinyspuds
Does anyone have a tip for remounting this bracket (the one that mounts near to rad). The left hand captive nut at the top is behind the hose to rad fixing and even if I took the hose off, the rad stub would still be in the way. Is there a trick or does the rad have to be moved (tricky for me as the sidecar subframe is too restictive)? It was reasonably easy to get off as the bracket was broken but I can’t get the bolt back in place with a complete bracket.
