1 Water pump rebuild very slow leak Thu Dec 07, 2023 5:32 am
KiwiK100
Hey everyone, have rebuilt my water pump and reinstalled it onto the engine. This is the third I’ve done over the years with the first two without issues. This one is fitted to an 84 and required a new shaft and updated impeller. I added coolant and overnight a telltale drip of coolant was on the floor. Traced to the tell tale drain hole. Engine has not been started. Drip rate is about one drop every 6-8 hours or longer. But it drips. Any thoughts on what I’ve overlooked? Old seal was definitely all removed, and gear pulled up nicely against the housing with virtually zero gap. I should note that the original shaft was replaced with a non genuine item through Munich MC in Perth, Western Australia, and the old gear was removed and pressed onto the new shaft by a reputable engine rebuilder. Thanks for your help.
Current rides:
2020 R1250RS. Metallic black with all the fruit
1983 K100C. Red. Krauzer fairing.
1984 K100RS. Madison silver.
2002 K1200RS. Owned from new. Pacific Blue, Ohlins, Speiglers, Fiamms, HID. 186,000km SOLD
1991 K1. Schwartz metallic black, 18 month frame off restoration. 74,000km SOLD
1987 K100RS Style. Black, Ohlins, Race Tech springs, Braided lines. Fully restored. 53,000 miles. SOLD
The family history:
1951 AJS 500 single - my Dads ride
1953 Triumph Terrier - my Mum's ride
1916 Triumph Type H, Battle of the Somme, France WW1 - my Grandads ride
