1Back to top Go down   Water pump leak Empty Water pump leak Sun Dec 27, 2020 3:19 pm
mritz
mritz
Hi there,
I've rebuilt my oil/water pump.
So, all fluids were flushed.
Now, with everything in place, tighten and siliconed... I've noticed a leak.
There is no pressure once I haven't replaced fluids yet. I've just moved the bike position.
a) Im intrigued why there's a hole / drain from the water pump? (See pics)
b) If it's leaking with almost no fluids (just a residual nothing) what will happen if I fill that up?
c) I saw a video o people making fun of other closing that drain with a screw...now I understand why...
It was some mistake I did rebuilding oil/water pump?
Thanks much!
Water pump leak Img_0612
2Back to top Go down   Water pump leak Empty Re: Water pump leak Sun Dec 27, 2020 5:19 pm
There's no telling what will happen until you fill it up and run it. We don't know whether that's oil, coolant or tears. It's unlikely though that detritus in your garage will be piled up against the overhead door by a pump leak-generated vortex but if that happens, please post some photos. You probably should open the door just in case, and wear overshoes.  Smile
The hole's purpose is to indicate at the earliest possible moment when seals are leaking rather than your finding out by having engine trouble caused by a faulty combo pump. Either oil and/or coolant will drip from that hole. You should fill the cooling system with the correct amount and ratio of distilled water and coolant according to instructions, fill the crankcase with oil in the correct amount, run the engine for a few minutes then shut it off. If no fluid is on the floor the next day, you're golden.
If there's only a drop or two keep calm. Some riders have been able to log thousands of miles accompanied by a few drips. Others can't tolerate uncertainty. If you need to go back in there to replace the replacement seals (you wouldn't be the first, by a long shot), save the coolant and reuse it if there's no oil in it.
There's a hole with a similar purpose on the underside of the transmission where it joins the engine. Either engine oil or transmission fluid will drip from that one when seal leaks occur.
What is the unit of measure for residual nothing?  Nanosomethings? Laughing
3Back to top Go down   Water pump leak Empty Re: Water pump leak Sun Dec 27, 2020 6:43 pm
mritz
mritz
It was zero DPHs (drops per hour)...
I've moved the bike and and I've noticed 1 DPH...
Im intrigued because I have almost nothing...
What seal you are talking about?
4Back to top Go down   Water pump leak Empty Re: Water pump leak Sun Dec 27, 2020 7:08 pm
mritz wrote:What seal you are talking about?
Which paragraph?
5Back to top Go down   Water pump leak Empty Re: Water pump leak Sun Dec 27, 2020 7:15 pm
mritz
mritz
Which paragraph?
2nd.
"...earliest possible moment when seals are leaking..."
6Back to top Go down   Water pump leak Empty Re: Water pump leak Sun Dec 27, 2020 7:59 pm
Did you encounter donut-shaped seals that fit over the shaft that has a gear on one end and an impeller on the other when you rebuilt it? If you did, those are them.
playlikewedream
playlikewedream
Hi K gurus,
I replaced the water pump seals on my 1990 K1, but the rubber oil side seal won't seat and there is a gap between the wall of the water pump and the seal no matter how hard I hit it.
Any help would be appreciated.
Water pump leak Ir-log10Water pump leak Ir-log10
;BMW; K1 1990 Laguna Blue and Yellow ;BMW;
;BMW; K1100RS 1997 Sedien Blue.;BMW;
Its not about the journey or the destination, it's about the friends you make on the way.
8Back to top Go down   Water pump leak Empty Re: Water pump leak Mon Feb 15, 2021 11:14 pm
Check very carefully and make sure there is not the remainders of the old seal still in there.
9Back to top Go down   Water pump leak Empty Re: Water pump leak Tue Feb 16, 2021 7:01 am
playlikewedream
playlikewedream
playlikewedream wrote:Hi K gurus,
I'm looking for some detailed photos or video of inside pump before and after seal is fitted, i would post photos of mine but the forum is telling me documents only.
10Back to top Go down   Water pump leak Empty Re: Water pump leak Tue Feb 16, 2021 10:02 am
playlikewedream
playlikewedream
Thanks Rick
Checked that all of the seal was out, and discovered that the original seal had a metal base and the new one is all rubber and hard plastic, tapped it out job done.
Cheers.
11Back to top Go down   Water pump leak Empty Re: Water pump leak Tue Feb 16, 2021 7:25 pm
:BW:
