1Back to top Go down   Greetings from the PNW Empty Greetings from the PNW Fri Jul 07, 2023 5:45 pm
CaptainHook
CaptainHook
Hi to the K100-forum,
I currently have a 1987 K100LT in gold trim which I got a couple years back. It sat in a garage for about 15 years before I got my greasy hands on it. Gas tank was badly gunked up, but after a thorough cleaning and other basic maintainance I got it running decently for the past two seasons. Currently I am having some serious problems that are tough to diagnose. Starts fine, but won't rev past 4000 rpm in any gear (not limited like a stuck throttle body but starts to bog down and die), and some added knocking. I assume a fuel issue and I'll start an actual thread if the new fuel injectors on order don't fix the issue. I checked for spun bearing and all looks okay without digging in too much.
As for my BMW experience I own and continuosly try to restore:
1981 BMW 633CSi in Alpine White on ACT gold wheels
1985 BMW e30 318i 2dr in Alpine White (sold Sad )
1985 BMW e30 318i 4dr in Alpine White
1987 BMW K100LT
2003 BMW Z4 with 3.0 swapped engine
Just got a 1972 Porsche 914 CV
This and other BMW threads have been a great help in many endeavors in the past and I'm glad to finally join in the discussion.
2Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Fri Jul 07, 2023 7:00 pm
Point-Seven-five wrote:Change the fuel filter in the tank with a new NAPA 8032.
NAPA 3032
3Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Fri Jul 07, 2023 9:24 pm
Hey!  A 3 is just a half ass 8.
4Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Sat Jul 08, 2023 2:36 am
bad boy
bad boy
hello CaptainHook
Greetings from the PNW 177912
Cheerz, David
Greetings from the PNW 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
5Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Sat Jul 08, 2023 6:28 am
6Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Sat Jul 08, 2023 6:30 am
firstle
firstle
flat battery
7Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Sat Jul 08, 2023 8:15 am
fishboy316
fishboy316
Welcome Hook!
8Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Tue Jul 11, 2023 9:39 am
Bernie_K100
Bernie_K100
Hi,
Greetings from the PNW 177912 to this forum!
Bernie
9Back to top Go down   Greetings from the PNW Empty Re: Greetings from the PNW Mon Aug 14, 2023 10:36 pm
CaptainHook
CaptainHook
Thanks for all the welcomes!
No change with new fuel injectors. The fuel filter was new with the first pump but I will pick up the 3032 and replace. Should have done this with the injectors...
The battery which is only a three year old AGM has been flat multiple times and I just tested it from full charge with nothing hooked up and a couple weeks later was weak, like 12.3v. I didn't think the higher rpm range would be impacted by a poor performing battery, but worth a shot to replace while picking up the fuel filter. Always willing to try the easiest solutions first.
Thanks again,
CaptainHook
