1 Bike won't start Mon Jul 03, 2023 11:51 am
vividcolt
So I got the bike to turn over on start fluid sprayed into the air intake. But it dies out after a few seconds. I can even work the throttle a little bit and it revs up but dies shortly after eating up all the starter fluid I spray. Without start fluid, it just cranks but will not turn over. I am trying to work out the electrical on the FI connector. Sparks work, fuel pump works, idk if the fuel injectors are working properly - they have positive voltage on the each connector, but having a hard time diagnosing that... I am wondering if it is a timing issue? Maybe an air flow detection issue? or Hall sensor issue? I will be testing volts and resistances on the LE-Jetronic (EFI) connector soon. Any thoughts on what the issue might be?
