1Back to top Go down   fuel pressure regulator Empty fuel pressure regulator Mon Aug 21, 2017 4:24 pm
timo27
timo27
Has anyone ever replaced the fpr with an adjustable pressure regulator via a gauge ? A new one is £90
2Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Mon Aug 21, 2017 4:26 pm
timo27
timo27
And what does the vacuum do on the pressure relief????????
3Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Mon Aug 21, 2017 4:27 pm
Chocolate
Chocolate
Hello!
Have seen something like that
fuel pressure regulator Img_3113
4Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Mon Aug 21, 2017 4:33 pm
timo27
timo27
Thanks mate that was just what i was thinking, its just the vacuum pipe i'm not sure about.
5Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Mon Aug 21, 2017 7:18 pm
Yes, the universal adjustable fuel pressure regulators sold on a popular auction web site will work fine and dandy with the K-100. So long as the FPR is capable of 2.5 - 3 Bar and the fuel hose fittings are compatible, you can swap. The vacuum line will not be used and the vacuum takeoff on TB4 can be capped.
6Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Tue Aug 22, 2017 1:20 am
timo27
timo27
Top man, i'll post pics in a couple of days.
7Back to top Go down   fuel pressure regulator Empty Re: fuel pressure regulator Fri Jun 02, 2023 10:17 am
SunnyPerth
SunnyPerth
How did you go with this @timo27? Did this work for you?
