51 Re: Did I goof? Sun May 14, 2023 1:34 pm
I don't have the wiring diagram, but I think there is a fan relay in the relay box. If you put a switched bypass across the contacts, you can turn on the fan with the switch.
On my K75S I got a piece of aluminum about 1" wide and 3" long. I put a hole for a toggle switch in one end and a hole to put it under the top fork pinch bolt on the left side. Bend the aluminum to get the switch in a convenient place.
I Polack engineered the connections to the relay by pulling the relay out of it's socket and sticking the stripped end of the wires in the sockets and putting the relay back in. Strip about 1/4" of the insulation off the end of the wire and twist the strands together. Make sure all the strands go in the socket. You don't want any loose ends causing short circuits.
