1Back to top Go down   86 k100 Spark Empty 86 k100 Spark Mon Apr 24, 2023 10:44 pm
boomhour
boomhour
I have a 86 K100 that I'm rebuilding from the ground up.  before I started the rebuild process the bike ran fine.  fast forward 9 months and I've rewired utilizing the m-unit blue and schematic from Mikey from Piha.  I don't have the gas can on the bike yet as I want to verify spark before I install the tank over the m-unit.
My issue is that I'm not getting any spark when I ground a plug and hit the starter motor.  the starter and battery are in good shape.  the starter sounds strong.  bike is in neutral for this test. plugs and wires are new and the correct 5ohm resitance type with bosch plugs. I have also tested the coils and they ohm out without cross talk signals. I've tested power at the ignition module and fuel injection module and everything seems good from what I've tested.  the temp sensor is brand new and installed per schematic.
I think everything is install and working except for the signal that tells the bike to spark.  I've read that the signal comes from the hall sensor.  how do I test the hall sensor?  when I hit the starter should I see the hall sensor turning?  right now I see nothing moving at the hall sensor when I hit the starter and am confused as to how the spark signal is initiated?
thanks for your help!
2Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Mon Apr 24, 2023 10:52 pm
moriarti
moriarti
The Hall sensor is fixed the shaft in the centre rotates  just like the distributor on a car. Very Happy
3Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 12:45 am
boomhour
boomhour
moriarti wrote:The Hall sensor is fixed the shaft in the centre rotates  just like the distributor on a car. Very Happy
Moriarti,  what should I do if the shaft and cup are not spinning when the starter is?  I believe this is why I'm not getting any spark.
4Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 12:54 am
Have you a neutral light on or clutch lever pulled in as normal?
5Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 12:55 am
moriarti
moriarti
SOB affraid affraid JUST TO BE CLEAR ENGINE TURNING OVER FINE IS THAT CORRECT
6Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 1:54 am
boomhour
boomhour
92KK 84WW Olaf wrote:Have you a neutral light on or clutch lever pulled in as normal?
Yes, the bike is in neutral and neutral light is on.  I do not pull the clutch in as I don't believe this bike requires the clutch lever to be pulled in to start. Maybe I'm wrong on the clutch lever switch?
7Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 1:59 am
boomhour
boomhour
moriarti wrote:SOB affraid affraid JUST TO BE CLEAR ENGINE TURNING OVER FINE IS THAT CORRECT
Yes, there is a full battery on a tender and starter seems to be strong.  But, I'm not seeing action behind the hall sensor with I hit the starter.
8Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 3:41 am
Is the starter motor turning the engine or is it just spinning?  The Sprag Clutch on these bikes is nown to have problems that prevent the engine from turning when the starter runs.
9Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 4:03 am
moriarti
moriarti
OK starter engages with engine, engine turns over ok. Now if the centre shaft of Hall censer is not turning you have a problem. you say it ran ok before. SO DOUBLE  CHECK what you have done up to now. Best of luck hopefully someone will have the answer 86 k100 Spark 78846 86 k100 Spark 78846
10Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 4:42 am
boomhour
boomhour
Point-Seven-five wrote:Is the starter motor turning the engine or is it just spinning?  The Sprag Clutch on these bikes is nown to have problems that prevent the engine from turning when the starter runs.
the engine is all buttoned up so how would I be able to tell if the engine is turning over?  I'm sure I installed the sprag clutch and gear in good working order as there were no issues before tear down.
11Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 4:51 am
moriarti
moriarti
OH DEAR Surprised Surprised REMOVE ALL SPARKPLUGS PRESS STARTER, WITH ENGINE SPINNING YOU WILL HEAR THE PUFF PUFF OF THE COMPRETION COMING OUT OF PLUG HOLES.
12Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 5:21 am
Starter sprag clutch problem. Sound familiar?
13Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 5:30 am
boomhour
boomhour
moriarti wrote:OK starter engages with engine, engine turns over ok. Now if the centre shaft of Hall censer is not turning you have a problem. you say it ran ok before. SO DOUBLE  CHECK what you have done up to now. Best of luck hopefully someone will have the answer 86 k100 Spark 78846 86 k100 Spark 78846
Yes, it ran fine before tear down.  all covers were removed and painted but the block was not separeted past the oil sump/output shaft. I also tore down the starter motor for cleaning and painting.  the sprag was removed as part of the tear down but I believe It went back in the right way as there are videos online that I followed along with.
before I undo the entire back end of the bike to get at the sprag, is it possible that I somehow reversed the polarity on the starter motor and its spinning the wrong direction?  I did tear it apart to clean and paint.  If that's not possible then I'll refer to the sprag trouble shooting link that i've see around to see if I can get the hall senor signal going.
Laitch, yes it sounds like the video you linked.  I wonder if the assembly lube I used to put things back together is an issue?
14Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 5:51 am
boomhour wrote:Laitch, yes it sounds like the video you linked.  I wonder if the assembly lube I used to put things back together is an issue?
If the sprag clutch was disassembled entirely, the sprags themselves could have been reassembled in reverse orientation causing this lack of engagement. The sprags should not have been lubed. What type of assembly lube was used?
The crankshaft has counterclockwise rotation when viewed from the front of the engine.
15Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 5:57 am
moriarti
moriarti
So the engine IS NOT turning over.
16Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 5:58 am
Yes, it is possible, and actually pretty easy to put the starter back together so it runs backwards.  I believe it has to do with the polarity of the permanent magnets if the body is installed 180 degrees out.  You are supposed to mark the end caps to the body to avoid this problem.
There is information here on clleaning and servicing starters.  You might want to do a search and read up on the process.
As far as the sprag, I would not worry about lube in it, it get lots of lube oil in the engine.  The main problem seems to be dirt preventing the pawls from rocking down to lock the clutch so it can spin the engine.
17Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:02 am
Point-Seven-five wrote:As far as the sprag, I would not worry about lube in it, it get lots of lube oil in the engine.
Was it you who wrote about molybdenum in crankcase oil causing faulty sprag clutch engagement necessitating flushing and replacement of oil to restore its function?
18Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:13 am
Who, me???
That was someone who hacked my account.  That idiot loaded up the cams and output shaft gears with molybdenum assembly lube that got into the engine oil and a while later it got into the sprag requiring an engine flush and oil change.
It appears that I still have that haunting me.  See, kids, the interweb is forever.
Having denied the above, I think that as long as the original poster didn't put molybdenum all over the place and used a moly-free assembly lube he should be okay.  I stand by my advice to check the starter motor first before embarking on the tribulations of getting to the sprag.
Even if he did load things up with moly like that guy who hacked my account, he can get things corrected by doing an engine flush by running a while with Seafoam in the engine oil and doing an oil change.
19Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:20 am
Point-Seven-five wrote: . . . I think that as long as the original poster didn't put molybdenum all over the place and used a moly-free assembly lube he should be okay.  I stand by my advice to check the starter motor first before embarking on the tribulations of getting to the sprag.
Hence my query concerning the type of assembly lube used  You're a memorable instructor. Laughing
Reverse starter rotation certainly a possibility.
20Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:52 am
No, neutral light on should do it. But it is good to pull the clutch anyway as its less load on the starter.
But others have mentioned starter running in reverse. However if that happens all you get is a whine and the engine does not turn over.
21Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:55 am
boomhour
boomhour
Point-Seven-five wrote:Yes, it is possible, and actually pretty easy to put the starter back together so it runs backwards.  I believe it has to do with the polarity of the permanent magnets if the body is installed 180 degrees out.  You are supposed to mark the end caps to the body to avoid this problem.
i cleaned the sprag with break cleaner before reinstalling it so it should not have anything binding it up.
I believe I used amsoil assembly lube but will check when i get home.
22Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 6:56 am
boomhour
boomhour
moriarti wrote:So the engine IS NOT turning over.
I'm really not sure now.  from the video posted it seems as thought the starter is just spinning and not turning the engine over.  my observations of at the open hall sensor vault confirmed no turn over is happening when starter is running.
23Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 7:01 am
boomhour
boomhour
i did not remove the sprags themselves.  I simply cleaned the assembly and put it back in per the video tutorials I found online here. see minute 7:00
24Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 7:25 am
boomhour wrote: I simply cleaned the assembly and put it back in per the video tutorials I found online.. . .so it should not have anything binding it up.
OK, you sprayed the sprag clutch with brake cleaner. Did you move each sprag to be certain it was not gummed up and moved easily?
It's likely either that the sprags in the starter clutch are slipping because:
they are not gripping the clutch's hub because of excess lube;
they're not rotating on their axes to engage the hub because they're still dirty;
or
the engine shaft assembly is rotating in the wrong direction for sprag engagement because the starter was mis-assembled. The noise in the video indicates a starter clutch problem likely caused one or more of those reasons.
Check the starter's rotation.
25Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 7:27 am
boomhour
boomhour
or
thank you.  I will pull the starter and most likey i have installed it 180 out as it was a couple months sitting on the bench waiting for paint etc with no regard given to orientation.  So I'm clear, it shoud be spinning counter clockwise when facing the gear?
26Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 9:10 am
boomhour wrote: So I'm clear, it shoud be spinning counter clockwise when facing the gear?
86 k100 Spark K100_e11
27Back to top Go down   86 k100 Spark Empty Spark Tue Apr 25, 2023 10:40 am
daveyson
daveyson
If these four alignment marks don't line up, you want to have another go at it. If they do line up, it's spinning the right way.86 k100 Spark Img_2098
 ~120,000 km
28Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 11:12 am
boomhour
boomhour
success.  the starter motor housing was installed 180 off which was confirmed with the starter off the bike.  I simply turned it upside down and I now have spark.  thanks for everyone jumping in the educate me.   86 k100 Spark 314114
29Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 12:17 pm
I once bought a K once where somebody had forgotten to put the two bolts back in so the starter was loose. Surprisingly it still started and ran fine. (Yes, I replaced them when I discovered this.)
30Back to top Go down   86 k100 Spark Empty Re: 86 k100 Spark Tue Apr 25, 2023 1:05 pm
boomhour
boomhour
duck wrote:I once bought a K once where somebody had forgotten to put the two bolts back in so the starter was loose. Surprisingly it still started and ran fine. (Yes, I replaced them when I discovered this.)
it's in there snug.  I had to come at it with a 24" pry bar up under the alternator from the right side.  nearly took the bike off the center stand.   Shocked
