parky
parky
Swapped out fan circuit connector block with hazard light switch block.
These connectors are the same form factor, and whilst working in dim lighting I reconnected them incorrectly ...only about 3 years ago (and until now Very Happy ).
I was sometimes perplexed at why the radiator fan had never come on ... and although I hadn't clocked up huge miles; was musing other than an overheating issue what impact (s) this might have had on other things such as, for example fuel consumption, spark-plug appearance etc. (if any)
Any thoughts would be appreciated.
1991 BMW K100rs (16v)
If the temp warning light in the cluster never came on then it's a non-issue.
parky
parky
Good. So where does the warning light get its signal from?
From this:
Inadvertently plugged the wrong hole  D8d69a4e-9200-4da8-b2fb-74e0450f60b0?rule=$_59
It monitors the coolant temp and turns on the fan at 103C, the temp light at 111C. Not surprising that your light hasn't come on. Unless the outside temp is very hot AND you stop for a few minutes the coolant temp usually won't get up to 111 when the fan doesn't come on at 103.
parky
parky
Great, thanks for explanation; you are one of the many 'good buggers' tirelessly keeping K-series bikes keeping on.
