1 1985 K100rs no Injector Pulse Sun Feb 26, 2023 7:02 pm
Zacdonov
Went to start my k100rs and found no fuel is spraying from all 4 injectors.
Fuel pump is new and audibly primes.
New fuel filter
Sent in to service all 4 injectors professionally and flow rates are good injectors open and close.
I have fuel pressure at the fuel rail.
Using a multimeter i found 12 volts on both terminals to all 4 injector connectors when grounding to the frame. But when putting both multimeter probes to both terminals on each connector there is no power or pulse when pressing the starter.
Following Crazy Frogs troubleshooting guide how should i test for a grounding pulse when measuring at the Injection ECU?
New fuel filter
