![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![Life time member Life time member](https://i.servimg.com/u/f80/11/71/56/74/bmw-5s10.gif)
Number of posts : 7942
Next time you try to start it, keep your finger on the start button.
If this keeps it running, then your fuel system is running ok, its getting fuel, its getting spark.
What its not getting is the signal from the Hall Sensors to the fuel pump/fuel pump relay. But if its firing with your finger on the start button your Hall sensors are giving signal to the ignition system so its reaasonalbe to assume its not a HES problem.
Check your injection control unit under the seat, the big plug connector and make sure all the pins are clean. It gets power from 2 pins, not one. One is from the start button, the other is from the HES. If no joy then you need to do the same with the Ignition control unit under the headstock.
1971 Yamaha 125 YAS-1
