1 High beam switch Mon Jan 17, 2011 11:40 pm
Stout
The high beam on my 1986 K100RT works when I use the 'pass' push switch (top position), but not when I use the normal high beam switch (bottom position). I've pulled the left switch panel off the handlebar and inspected the switch connections and contacts as well as I can without further disassembly, but the cause is not obvious. Wires are all solidly connected and what I can see of the contacts look OK.
Has anyone else struck this problem? Is my interpretation of the switch positions and functions correct?
Since it isn't the bulb and doesn't appear to be the switch, I'm wondering if perhaps the normal high beam position lights the filament via a different relay from that used by 'pass' position?
