1Back to top Go down   Is this wiring legit? Empty Is this wiring legit? Tue Jan 17, 2023 1:43 pm
brianpen
brianpen
Found this wiring configuration tapped into the number 1 fuse. Is this something a previous owner did to find switched power? Or is there another explanation? Thanks.Is this wiring legit? 20230110
2Back to top Go down   Is this wiring legit? Empty Re: Is this wiring legit? Tue Jan 17, 2023 2:26 pm
Done by a PO. Fuse no.1 should have a green wire with a black tracer on one side (green/black) and a green wire with a yellow tracer on the other (green/yellow). I can't be certain from the picture, but it looks as if the green/yellow has survived and the Scotchlok (horrible thngs! - should be banned outright) has been clipped to the remains of the green/black wire. If the green/black wire is still intact (can't see it) then yeah; he was looking for a switched connection. Trouble is, if it has any real load on it then it's going to cause problems because it routes through the kill switch.
Where does it go?
3Back to top Go down   Is this wiring legit? Empty Thanks Dai Tue Jan 17, 2023 3:20 pm
brianpen
brianpen
Thanks for the quick response.
It is routed up to the headlight area. I thought I would use it to power led driving lights (minimal draw). Or do you think I would be better off to just grab power from a turn signal?
4Back to top Go down   Is this wiring legit? Empty Re: Is this wiring legit? Tue Jan 17, 2023 3:46 pm
How much draw for the LEDs?
Where I tap things in for switched power is the Green/Brown wire of the round white nylon alarm connector.  That is switched power via Fuse 7.
5Back to top Go down   Is this wiring legit? Empty Re: Is this wiring legit? Tue Jan 17, 2023 4:05 pm
brianpen
brianpen
10 watts x 2 Cree leds. Mostly for conspicuity during the daytime.
6Back to top Go down   Is this wiring legit? Empty Re: Is this wiring legit? Tue Jan 17, 2023 7:21 pm
Those will be fine run from the green/brown wire.
7Back to top Go down   Is this wiring legit? Empty Re: Is this wiring legit? Wed Jan 18, 2023 7:11 am
I'm in agreement with Duck. That's a 1.5 amp current draw, so not too much.
