2 Re: K100 belly pan Thu Dec 08, 2022 12:01 am
That'd be anyone's best guess. This is an aftermarket belly pan, not something sold originally by BMW.
1977 R75/7-100, '93 K11/K12 Big Block, '93 K1100RS, '95 R100 Mystic, '96 K1100RS, 2 x '98 K1200RS, '06 K1200R & '09 K1300GT
3 Re: K100 belly pan Thu Dec 08, 2022 1:19 pm
RS Rider
It certainly "looks" like it would fit a brick engine. It would obviously need a mounting kit to fit it. And speaking to that, the mounting holes in the belly pan are much lower than the stock BMW belly pan (assuming a brick engine of course) or my Flat Racer aftermarket one which fits like OEM unit. It does appear to have cutouts in front LH and RH corners for cam cover and rad hose respectively, although it doesn't have the cutout along the LH rear for the 4 header pipes, so wondering if this unit is slightly wider.
There is a small panel on the RH side that is retained by a screw. This appears to be around the area where one would view the oil level sight glass.
The left and right rear mounting arms appear to have double-sided tape on them. Does it also hang somewhere?
I'm curious to know what this fits.
4 Re: K100 belly pan Thu Dec 08, 2022 2:09 pm
I suspect that it isn't for a K bike. It is too symmetrical and the vertical parts at the rear don't look like they are intended to fit the K engine crank and valve covers.
5 Re: K100 belly pan Sat Dec 10, 2022 7:27 am
Looks like it's gonna fit under the 2V RS fairing
K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
6 Re: K100 belly pan Sat Dec 10, 2022 8:14 am
No. I've got two 2V belly pans hanging up and there's no way that one will fit. My guess - FWIW - is that is off a Pan European or similar.
7 Re: K100 belly pan Sat Dec 10, 2022 9:55 am
Looking at the RHS picture, there is no hole provisioned for the oil level sight glass and the holes made for the crash bars are in the wrong places. This is not a belly pan made for a K series.
8 Re: K100 belly pan Sat Dec 10, 2022 2:05 pm
One way to solve the riddle, just fit it under a K
9 Re: K100 belly pan Sat Dec 10, 2022 2:27 pm
In my downtime I went for a wander in the garden of the Google gods looking at piccies of various Japanese & Italian sport-touring motos. None, in any engine config, had a pan that quite resembles this one. I'm in agreement with Arlina. Chuck it up under something K and see how the undies fit.
10 Re: K100 belly pan Sun Dec 11, 2022 12:12 am
Looks like it's for an 8 valve K100RS. I just stumbled across this eBay listing. It is a TCP belly pan. Check the photo of the installation instructions. Kind of neat feature is that you don't need to remove it to do an oil and filter change.
https://www.ebay.com/itm/275467575000?hash=item4023259ed8:g:iUAAAOSwOGtjKMgh&mkcid=1&mkrid=711-53200-19255-0&siteid=0&campid=5337848011&customid=&toolid=10001&mkevt=1
11 Re: K100 belly pan Sun Dec 11, 2022 11:54 am
Well, whaddyaknow!!!!
12 Re: K100 belly pan Sun Dec 11, 2022 1:27 pm
RS Rider
There you go! New one at that.Point-Seven-five wrote:Looks like it's for an 8 valve K100RS. I just stumbled across this eBay listing. It is a TCP belly pan. Check the photo of the installation instructions. Kind of neat feature is that you don't need to remove it to do an oil and filter change.
13 Re: K100 belly pan Tue Dec 13, 2022 2:10 pm
All the way Richy, all the way......
14 Re: K100 belly pan Tue Dec 13, 2022 5:42 pm
I have one in the shed its fits the 8v k100 rs
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
Similar topics
