jjefferies
jjefferies
Hello all. ?Blue '86 K100,
Now that I've got the throttle cable installed, maybe, hoping, it's time to move on to the various under the tank wires. Are there any lists of the various wires, their connector's for identifiction, and where they are positioned/placed?
J.
There is a picture of where a connector is under the tank, which answers 1/3 of your ask
Identifying connectors K100  & posiioning wires Under-tank-wiring
Another one-third is that most of the connectors are polarised so will only connect to their partner. Until you come to the clutch, front brake, rear brake and fast idle which are all yellow because it's the same physical switch type...
robmack wrote:There is a picture of where a connector is under the tank, which answers 1/3 of your ask
What's "5-Starter switch" in that diagram?
Dai wrote:Another one-third is that most of the connectors are polarised so will only connect to their partner. Until you come to the clutch, front brake, rear brake and fast idle which are all yellow because it's the same physical switch type...
Clutch switch - BLK/GRN & GRN/BLK
Front brake - GRA/RED & GRN/BLK
Rear brake - GRA/GRN & GRN/BLK
Choke(fast idle) - VIO/WHT & Brown
jjefferies
jjefferies
Thanks for the info.
J.
7Back to top Go down   Identifying connectors K100  & posiioning wires Empty Wiring Sat Nov 05, 2022 6:10 pm
daveyson
daveyson
Number 5 is the plug for the ignition key switch, the plug beside it that joins the loom with 4, is for the flasher cancel button. The drawing puts the flasher cancel at plug 1, so I think that's a typo.
 ~120,000 km
The picture isn't wrong. The orientation is strange. The front of the motorcycle frame is at the bottom of the picture, the relay box at the top, the right side of the motorcycle on the left and visa versa for the left side.
9Back to top Go down   Identifying connectors K100  & posiioning wires Empty Wiring Sun Nov 06, 2022 12:06 am
daveyson
daveyson
True the drawing is correct and tricky with the front at the bottom, I think it's just labeled wrong with plug number 1, they put it at the front, but actually the flasher cancel plug is between plug number 4 and 5.
 ~120,000 km
You're right about the turn signal cancel connector being near "4". Odd that they have drawn a dangling plug near "4" but not labelled it with "1" because that is exactly what the connector looks like.
