1 Strange Caliper Bolt? Thu Nov 10, 2022 1:00 am
When Bruce had the tyres on his 75s changed the tyre fitter encountered a problem fitting his RH front caliper. As the brakes had to come off to allow the rims to be powder coated I decided to have a closer look. The LH caliper has normal bolts the RH calipers upper bolt is normal however the lower bolt is shouldered and the mounting point on the fork leg is partially tapped out. Has anyone encountered this before?
