1Back to top Go down   Greetings from Australia Empty Greetings from Australia Wed Oct 19, 2022 12:27 am
funtimer55
funtimer55
This new member sends greetings from Toowoomba, Queensland, Australia.
I have just acquired a 1985 K75C. It has travelled over 180,000km and needs restoration work.
I know very little about BMW bikes but learning about them is the thrill of it all.
Looking forward to being part of the forum.
Jeff Dorman
Other bikes:
1982 Yamaha SR185 on the road
1980 Honda CX500 on the road
1954 AJS 350 runs but still in the shed
2Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Wed Oct 19, 2022 1:18 am
Greetings, !80,000 K's is nothing for a well maintained K. I've got 180,000 K's on mine and it runs like a top uses no oil between changes and still on most of its original parts. I've had to adjust two valves at 140,000 K's. Lots of forum members in and around Brizzie and lots of help available.
3Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Wed Oct 19, 2022 4:12 am
Bricks do not like sitting. A spray of oil in the low cylinder can free up the rings which are known to stick when left sitting. Alternatively riding it will also free up stuck rings, it can however take a couple of 1000 K's. The internal and external fuel hose and the fuel pump damper will have deteriorated and they don't like ethanol laced fuel. The fuel hose in the tank must be rated for fuel injection and be submersible.
Electrical connections are also be known to suffer when left especially in damp conditions. It is worthwhile cleaning all the connectors and earths with an electrical cleaner Deoxit is one and can be obtained from Jaycar. The 75's are extremely bullet proof even more so than the K100's but the need to be maintained . Drive shafts need to be lubed and cleaned every rear tyre change as a precaution. If not maintained they can wear out the splines, mine is still fine because it has been maintained.
 Any questions that you have can be answered. The brains trust is very good. Anytime you are down in Nort Lakes you are welcome to drop in you have just missed a workshop day.
4Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Wed Oct 19, 2022 10:57 pm
Jamie64
Jamie64
Welcome
K1100RS 1993
Moto Morini 3 1/2 1974
R9T Racer 2017
5Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Thu Oct 20, 2022 8:08 am
td5
td5
Welcome from WA, tons of help just ask
Mike
Greetings from Australia K_engi10
1988 / K100RS
2013 / R1200GS
2015 / K1300R
2002 / R1100S BCR
6Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Thu Oct 20, 2022 3:18 pm
bad boy
bad boy
hi Jeff
Greetings from Australia 177912  here
enjoy!
7Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Fri Oct 21, 2022 12:22 am
Welcome from the bottom of the hill
1986 K100 RS Motorsport
1988 K100 RS SE
1990 K1 known as Barn Find
#### K100 RS Project
8Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Fri Oct 21, 2022 3:53 am
Welkom Jeff,
Sounds like it is just run in.
9Back to top Go down   Greetings from Australia Empty New Member Fri Oct 21, 2022 4:38 am
Pegasus
Pegasus
Hi Jeff,
I'm at Ipswich if you need any help.
Cheers,
Andrew
10Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Fri Oct 21, 2022 10:12 am
fishboy316
fishboy316
Welcome! Good luck with the bike.
11Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Sat Oct 22, 2022 10:38 am
Welcome Jeff Smile
Greetings from Australia Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
12Back to top Go down   Greetings from Australia Empty Re: Greetings from Australia Thu Oct 27, 2022 11:57 am
Bernie_K100
Bernie_K100
Hi Jeff,
Greetings from Australia 177912 to this forum!
Bernie
