1Back to top Go down   Coolant Change Empty Coolant Change Tue Nov 01, 2022 9:47 am
yamaguzzi
yamaguzzi
I'm beginning a major service on my 1988 K100RS and starting with a coolant change. I have been reading on various sites that Prestone long life concentrate with distilled water is a good choice . I'm trying to avoid using BMW coolant and paying extra for what? Has anyone used this Prestone or similar stuff and if so how did it work out.
2Back to top Go down   Coolant Change Empty Re: Coolant Change Tue Nov 01, 2022 10:21 am
Bricklayer
Bricklayer
This easy is easy to find at Wally World (WalMart). No problems after many years of use (and changes) on my high mileage K100RS.
Coolant Change 2022-110
Anthony Mrugacz
https://anthonymrugacz.net
View Past Stable of Ponies:
1978 Suzuki TS185
1976 BMW R90/6
1973 Yamaha LT3-MX
1970 BMW R75/5
1970 Suzuki T500
https://anthonymrugacz.net/
3Back to top Go down   Coolant Change Empty Re: Coolant Change Tue Nov 01, 2022 10:44 am
I have used it with no bad effects.  Also used Peak and NAPA coolants as well.
I'm pretty sure any universal Long Life coolant will be compatible with the Brick's aluminum engine.  What I understand is that back in the 80's when the Bricks were first introduced most coolants were formulated for cast iron engines.  Today, aluminum alloy is almost universal and the formulas have been changed to accommodate it.
The price of the coolants at Walmart is low enough that I can afford to change it every two years, further protecting the engine from corrosion.
Last edited by Point-Seven-five on Tue Nov 01, 2022 5:26 pm; edited 1 time in total (Reason for editing : fat fingers)
4Back to top Go down   Coolant Change Empty Re: Coolant Change Tue Nov 01, 2022 2:15 pm
yamaguzzi
yamaguzzi
Thanks ! Now I know .I didn't want to just do it and regret it later.
5Back to top Go down   Coolant Change Empty Re: Coolant Change Tue Nov 01, 2022 5:12 pm
Suzi Q
Suzi Q
And....
coolants come in GREAT colours these days!  Coolant Change 1f600
6Back to top Go down   Coolant Change Empty Re: Coolant Change Tue Nov 01, 2022 5:39 pm
I've been using OEM coolant with distilled water for 20 + years & 180,000 K's and I'm still running all original cooling system parts. I have coolant test strips and change the coolant as required. I've flushed it a couple of times and found that the flushing didn't flush out anything and was a waste of time. In preparation for another coolant change I bought a bottle of OEM coolant to find that it has changed to Lifetime coolant. I was paying $16.00 Au a litre for the BMW coolant the lifetime coolant was $24.00 a litre. I have yet to use it.
Coolant Change Castro12
Coolant Change Bmw_co11
Coolant Change Pb020010
