battery advice Tue Aug 02, 2022 7:04 pm
pirhanaxv
![pirhanaxv](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
![New member New member](https://2img.net/i/itest/ranks/default/default1.gif)
I recently bought a taller battery, similar in size to the Westco 12V30AMP. Stock screws for the battery hold down are too short so I was getting ready to order the longer screws from beemer boneyard. But there is an additional problem of the coolant reservoir hold down. The stock battery hold down has a rubber bushing that fits over the coolant reservoir. With the taller battery the bushing does not reach down to the reservoir so the reservoir will be bouncing around unless I secure it with tie downs or maybe look for an extension to the bushing. Before I order the screws and get creative with the reservoir I though I would ask to see if anyone has already found a good solution for this.
