1 Suitable sealant to use for oil-water pump Tue Aug 01, 2023 11:23 am
Hi,
I am only able to choose from a limited set of Drei Bond (Three Bond) sealant products so I'm also looking for alternatives to Three Bond for sealing the oil-water pump to the block.
I can get Three Bond 1211 but not the Three Bond 1108. Is the 1211 suitable? If so, I'll get that sealant.
I can also obtain Permatex Anaerobic Sealant (#51850) locally. It is a noncorrosive gasketing material designed primarily for use on aluminum, iron, and steel flanged mating surfaces. Cures to a solvent-resistant seal that will not tear or decay during service. Is it a good substitute for Three Bond?
I also have Grey RTV but I've read differing opinions about using that material in this application.
