1Back to top Go down   clutch friction plate wear Empty clutch friction plate wear Sat Jul 23, 2022 5:07 am
madhatter
madhatter
Hi guys and gals , got my clutch apart and just checking the wear on the friction plate , its currently 5.5mm thick , specs recommend replacement at 4.5mm . how much use can one get from 1mm and how thick is a new plate? im inclined to replace it but im curious  Shocked
current - 86 K75s , 93 K75s , 07 CBR1000RR , 04 YZFR6 , 83 GSX1100SD Katana , 1997 XV Yamaha Virago 1100 , 1983 Kawasaki Z1000 J3 ,
previous XL100 , Suzuki SP370 , GPZ550 , 81 GSX1100SD Katana , 98 Ninja 900
2Back to top Go down   clutch friction plate wear Empty Re: clutch friction plate wear Sat Jul 23, 2022 5:44 am
Experience on here shows that 3.5mm is about the screaming 'replace me!' point. I've run one down to 3.0mm before the constant slippage finally got to me. As for 'how much use' - that depends on how heavy your right hand is. Could be as little as 20K miles, could be as much as 120K miles.
3Back to top Go down   clutch friction plate wear Empty Re: clutch friction plate wear Sat Jul 23, 2022 7:31 am
madhatter wrote:Hi guys and gals , got my clutch apart and just checking the wear on the friction plate , its currently 5.5mm thick , specs recommend replacement at 4.5mm . how much use can one get from 1mm and how thick is a new plate? im inclined to replace it but im curious  Shocked
About 5.5mm check that the steel plates aren't dished which makes them slip as they only touch at the outer edge.
4Back to top Go down   clutch friction plate wear Empty K Clutch Sat Jul 23, 2022 9:12 am
Tinker
Tinker
I had trouble with slipping way before the thickness limit, wear on the mechanism was such that it couldn't clamp properly any more. I have a lathe, so after removing the location dowels, I was able to turn down the three raised portions to compensate. It was some time ago, I can't remember how much I took off, but I measured the wear on the pressure plates and took that much off. It wasn't a lot 0.5mm or so! It' run for at least six years like that!
Cheers, Matthew
5Back to top Go down   clutch friction plate wear Empty Re: clutch friction plate wear Sun Jul 24, 2022 10:36 pm
madhatter
madhatter
excellent , this must be a new clutch im looking at then . Very Happy
