1Back to top Go down   Greetings Empty Greetings Thu Jul 21, 2022 11:16 am
pendullumx
pendullumx
I bought a 1995 K 75 after hearing about how bulletproof
Getting the K75, was great, but I found out that bad gas was sitting in it long enough to make all the
parts(pump, screen, damper, hoses and wiring etc.) in the tank, toast.
 Any and all advice, (help?) and if there are any parts around, let me know.  I look forward to meeting the Brick lovers!
2Back to top Go down   Greetings Empty Re: Greetings Fri Jul 22, 2022 8:17 am
Porto
Porto
Welcome mate. Great bike to have in the stable. That shouldn’t be to bad a job. Strip out the tank, clean it and start fresh. Pump, filter, strainer and hose are relatively inexpensive. Flush the rail and clean and test the injectors. I’ve been where you are, I had the added problem of water corroding the tank under the fuel pump. Painful to repair the aluminium tank. My model is older than yours and from what I was told it sat parked a few years. After fixing all this I got ten years trouble free riding. The last two years I’ve had plenty of problems. Lucky for me I’ve had plenty of help resolving them with help from the forum members.
3Back to top Go down   Greetings Empty Re: Greetings Sat Jul 23, 2022 12:56 pm
Bernie_K100
Bernie_K100
Hi,
Greetings 177912 to this forum!
Bernie
