Robmack, You asked "Can you test the HES at ICU pins 5&13?" That's a great question! Can I? Will the LED test work there, too? I don't know exactly how I'd hook that all up, but maybe it could work. Question, though: Would I be getting spark at all if the ICU wasn't getting the hall signal? Doesn't spark timing come from that?
Thank you for that diagnostic page! That could be really helpful. I'll dive in on that next time I work on the bike.
re: resistance on the spark plug leads. These are the same leads that have been working fine for thousands of miles. Can the resistance on those fail? I'll check it, though. One more thing to take a look at. Though, the more I'm thinking about the spark plug timing, the more I'm thinking it's a dead end. I'll follow up on it, of course, but I think I must have just had some weirdness of my timing light. Especially since you're confirming what I thought: 1 and 4 fire at the same time. It's hard to think of a way that 1 could be firing normally but 4 would be firing only half the time. It must be my timing light.
Plugs are NGK D8EA. They're new, but the same as I've been using for many years.
I'm going to check the resistance on the coils, too. Such an easy test there's no reason not to do it.
GTJos,
That's an interesting thought. I'll take a look. The fuel pump is always running just fine, even when the bike is messing up. But that's only one of the two outputs from the relay, right? And the other output is power to the injectors? I've heard the injectors clicking through a stethoscope while the bike is messing up. But you know what, I just realized I did that stethoscope test with only one injector. I'll take a look at that relay connection and also listen to the rest of the injectors to see if they're all clicking.
Daveyson, The problem seems to have become permanent. Early in the testing I had brief periods of the bike running normally for many minutes on end, but not in the last week or so. It's only messing up now.
How did I get readings for 9 and 14? I had the positive probe of my voltmeter stuck into the back of the ICU plug at 9 and 14, and the negative probe against the engine block. The readings I got doing that were 12 volts as soon as I turned the ignition on, dropping to 9-10 volts while the starter was running.
I'm curious how you got your bike running without a fuel pump. Was that just gravity feed to the injector rail?
From your second post, yes my timing light has a directional arrow. I'm pretty sure I got that right. I even double checked after I got a weird reading. But I have had issues with the timing light from time to time. Using it on my R60, I have to hold the lead exactly in the middle of the the timing light pickup for it to register at all. I'm really starting to think the spark timing anomaly was just a quirk of the timing light (but I am still going to follow up on that.
As for behavior of the coils, my guess would be that each coil behaves like the setup on my boxer. Each coil sends out two sparks at the same time, once per revolution. When 1 is getting its necessary spark, 4 is getting a wasted spark at the end of its exhaust stroke. But that's just a guess. I'm sure someone here can confirm.
Porto, You're totally right. The last time my bike had one of its brief moments of running well it started while I was checking for spark. I had plug 3 pulled. All of a sudden the bike started working. It was running a little rough for the lack of that one cylinder, but it was running. Not all that badly, really
So, yeah, even if I do actually have a problem with the spark on cylinder 4, the bike would still be running.
