1Back to top Go down   Temp gauge Empty Temp gauge Fri Jun 10, 2022 7:44 am
fishboy316
fishboy316
Trying to get the temp gauge to work. Checked fuses found them ok. Checked voltage at the gauge was only getting 10.5 vdc. Should I get 12vdc there? What I did see was after doing this it looked like the gauge needle was trying to move when power was turned on. Wasn't doing this before.
Also have any of you tried the quick disconnects for fuel lines to the tank?
2Back to top Go down   Temp gauge Empty Re: Temp gauge Fri Jun 10, 2022 2:02 pm
RS Rider
RS Rider
fishboy316 wrote:Trying to get the temp gauge to work. Checked fuses found them ok. Checked voltage at the gauge was only getting 10.5 vdc. Should I get 12vdc there? What I did see was after doing this it looked like the gauge needle was trying to move when power was turned on.
Yes, you should have 12VDC at the gauge. If you have 12VDC at the gauge and ground the brown wire the needle should fully deflect to the right. Grounding (to frame) the wire at the temp sender by water pump will do the same thing.
I haven't but it is something I have thought about. PITA draining gas and removing 2 fuel lines to remove the tank.
3Back to top Go down   Temp gauge Empty Re: Temp gauge Sat Jun 11, 2022 10:30 am
fishboy316
fishboy316
Thanks RS rider. I am going to need to track down the low voltage issue. Could also need a new vdo sensor. Not sure if PO put a new sensor in when the vdo gauge was installed.   Need to figure out what sender is in it.
I think I am going to give the Quick  disconnect a shot. As much as I have had the tank off lately it will be worth it. It is a pita!
Thanks again.
4Back to top Go down   Temp gauge Empty Re: Temp gauge Sat Jun 11, 2022 12:37 pm
fishboy316 wrote:I think I am going to give the Quick  disconnect a shot..
Beemer Boneyard, again.  Smile
5Back to top Go down   Temp gauge Empty Re: Temp gauge Sat Jun 11, 2022 3:20 pm
Make sure you get metal ones. There's a lot of sheer stress on the QDs when the tank is lowered into place and the fuel lines fold up.
6Back to top Go down   Temp gauge Empty Re: Temp gauge Sat Jun 11, 2022 11:54 pm
volador
volador
7Back to top Go down   Temp gauge Empty Re: Temp gauge Tue Jun 14, 2022 1:17 pm
fishboy316
fishboy316
Thanks for the info everyone!
8Back to top Go down   Temp gauge Empty Re: Temp gauge Sun Jun 19, 2022 8:11 am
fishboy316
fishboy316
Temp gauge is working. Turned out to be the sensor/sender. Spoke with the folks at VDO gauges and found that sensor was a VDO 323-088. the one that came out was nowhere near what went in. Working great with the new one.
Thanks again for the help
