1Back to top Go down   Hi from France! Empty Hi from France! Sat Jun 18, 2022 6:44 am
Tinker
Tinker
I've been on this forum for many years, but I couldn't remember my user name so I'm back again having rejoined!!
I have an 87 K100 (I've had it for about 12 years!) with problems!!
I sent this as an email to Bert:-
This is a last resort, I'm at my wits end, my 87 K100 starts well, pulls well up to 2500 / 3000 rpm and then shuts down, hot or cold,
I've changed the plugs fuel pump fuel filter, checked the injectors, fuel pressure OK, (changed and tested pressure relief valve) tested with and without idle switch, I tried another EFI _unit, tested all the pins everything exactly as required!
It's shutting down as though it was over revving any suggestions would be greatly appreciated!
Could it be that despite testing OK at the plug something weird happening with the flow meter?
Cheers, Matthew
2Back to top Go down   Hi from France! Empty Re: Hi from France! Sat Jun 18, 2022 6:56 am
moriarti
moriarti
:welcome:Back Tinker I too had a nightmare problem, cutting out loss of power, the culprit turned out to be the ICU ignition control unit situated under the tank near front of the frame, replaced  it ran like a dream. Hope this helps  Very Happy Very Happy
3Back to top Go down   Hi from France! Empty Re: Hi from France! Sat Jun 18, 2022 7:45 am
Welcome!  I agree with Moriarti.  I believe the ICU is where the over rev protection is implemented.
4Back to top Go down   Hi from France! Empty Re: Hi from France! Sun Jun 19, 2022 1:52 pm
bad boy
bad boy
salut Tinker - welcome back Matthew
bienvenu, Hi from France! 177912
Cheerz, David
Hi from France! 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
5Back to top Go down   Hi from France! Empty Re: Hi from France! Fri Jun 24, 2022 2:55 am
Tinker
Tinker
moriarti wrote::welcome:Back Tinker I too had a nightmare problem, cutting out loss of power, the culprit turned out to be the ICU ignition control unit situated under the tank near front of the frame, replaced  it ran like a dream. Hope this helps  Very Happy Very Happy
Thank!
I tried it, no different.
Subsequently, not straight after testing with another ICU it's not starting at all!back to the beginning, so far I've cleaned  the ground connections and all the cable connectors, The fuel pump, the fuel pressure regulator, the injectors tested as good the flow meter tests as good, I'm about to test the water temp and re test the hall sensors, which were the first thing I changed when the problem started! Not much left to try!
Cheers, Matthew
6Back to top Go down   Hi from France! Empty Re: Hi from France! Fri Jun 24, 2022 8:30 am
Thank!
Cheers, Matthew
Make sure temperature sensor is connected. If you have a poor electrical connection it may alter the mixture or if completely electrically isolated cause a refusal to start. Recheck the ICU connections and clean them.
7Back to top Go down   Hi from France! Empty Re: Hi from France! Fri Jun 24, 2022 3:43 pm
Welcome back Tinker Smile
Hi from France! Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
8Back to top Go down   Hi from France! Empty Hi from France Sat Jun 25, 2022 2:57 am
daveyson
daveyson
Since toying with the ICU made it worse, that would be a good place to look at again. If no help maybe go through Bert's guide until you hit a problem. If you get back to the original problem, unlikely but maybe have a quick look at the alternator plug, that it's clean and snug.
 ~120,000 km
9Back to top Go down   Hi from France! Empty Re: Hi from France! Sat Jun 25, 2022 4:32 am
Tinker
Tinker
Thanks, a good idea! that will be my next step! I just went over all the plug in connections and ground points, cleaned and protected them with Vaseline!
What a nightmare
Cheers, Matthew
10Back to top Go down   Hi from France! Empty Re: Hi from France! Mon Jun 27, 2022 11:38 am
Tinker
Tinker
daveyson wrote:Since toying with the ICU made it worse, that would be a good place to look at again. If no help maybe go through Bert's guide until you hit a problem. If you get back to the original problem, unlikely but maybe have a quick look at the alternator plug, that it's clean and snug.
Well, I didn't say the ICU made it worse, just it's got worse, but not straight after changing the ICU. I have tested the temperature sensor, not good, I'm waiting for a new one!
Cheers, Matthew.
