1 Hi from France! Sat Jun 18, 2022 6:44 am
Tinker
I've been on this forum for many years, but I couldn't remember my user name so I'm back again having rejoined!!
I have an 87 K100 (I've had it for about 12 years!) with problems!!
I sent this as an email to Bert:-
This is a last resort, I'm at my wits end, my 87 K100 starts well, pulls well up to 2500 / 3000 rpm and then shuts down, hot or cold,
I've changed the plugs fuel pump fuel filter, checked the injectors, fuel pressure OK, (changed and tested pressure relief valve) tested with and without idle switch, I tried another EFI _unit, tested all the pins everything exactly as required!
It's shutting down as though it was over revving any suggestions would be greatly appreciated!
Could it be that despite testing OK at the plug something weird happening with the flow meter?
Cheers, Matthew
Cheers, Matthew
