1Back to top Go down   Tool for Brake pad setting pin removal Empty Tool for Brake pad setting pin removal Wed Jun 01, 2022 10:34 pm
jjefferies
jjefferies
Hi, Anyone come up with a tool to pull the brake pad setting pins? The two longer pins on the right.:Tool for Brake pad setting pin removal Brake_10
In the past I've driven out the one at the non-looped end of the spring with a punch. But was wondering if there's a tool that could pull the pin out as it obviously has a place to grasp it.
best regards J.Jefferies
I just use a small drift. However you could modify a pair of pliers or vice grips with a bit of grinding.
They do have a special tool https://www.fcpeuro.com/products/brake-caliper-pin-bolt-remover-otc-7302-2 But I'll stick to the drift.
For only $123!  Think I'll get two.
Pete Riley
Pete Riley
I'll just do what I have always done. Use a pair of pliers!
moriarti
moriarti
Old school British know how Twisted Evil Twisted Evil
The forked side can be used to remove ticks, should the occasion arise.
jjefferies
jjefferies
MartinW wrote:They do have a special tool https://www.fcpeuro.com/products/brake-caliper-pin-bolt-remover-otc-7302-2 But I'll stick to the drift.
Hmm, wonder how difficult it would be to make one? Oooh, a new project.
jjefferies
jjefferies
Point-Seven-five wrote:For only $123!  Think I'll get two.
You got the price wrong. Its $123.99 e.g. $124.
Can't afford it.
Can't afford it.
Darn!  I can only afford one.
Here it is in action. Video yourself in action with your prototype.  cheers
jjefferies
jjefferies
To beat the FLAT RATE. Right On! Right On!
I'm with Martin as a punch man. Cheap and you can't lose them as any old bit of round steel bar will do! Very Happy
