1 Alarm Light (Bert's blood pressure monitor) Mon Jan 17, 2011 6:51 pm
Rickmeister
Lads, Just returned from 1300Km ride. Noticed at cruising speed (100 - 130Km/h), after 15 -20 minutes, the warning light starts to flicker on and off, then goes on solid. Dabbing the front brake will clear the alarm for a few minutes and then it starts slowly to flicker on and off again. Riding with the lights on. Switching to high beam made no difference. Switching the lights off (thinking it might be a dodgy lamp) made no difference. Dabbing the front brake will always clear the alarm. Also, the engine seems to be mis-firing, but not radically, just noticeably every now and then, but still seems to be going OK. At lower speeds, (<80Km/h) the problem goes away. The bike has ABS. The weather was warm to hot and humid.
- does anybody have a list of all the things which cause the warning lamp to light up.
- any ideas as to what is causing this? Could it be something to do with the load shedding relay?
(BTW, haven't drained the gearbox oil yet to see the state of the drain plug, re: slivers stuck to it.)
Thanx, Rick G.
Thanx, Rick G.
