1Back to top Go down   Binker relay question Empty Binker relay question Thu May 12, 2022 11:35 pm
Rockman
I have a K11 sidecar. The RHS blinkers are the originals, no problem there.
On the left (sidecar) I have LED blinkers. Naturally these flash at a high rate. I tried fitting the resistors in various configurations  without success. They continued to flash quickly.
What is the easiest solution to this?
2Back to top Go down   Binker relay question Empty Re: Binker relay question Fri May 13, 2022 3:00 am
Make the modification to the circuit card that disables hyper flash; there are numerous threads with pictures and instructions.
3Back to top Go down   Binker relay question Empty Re: Binker relay question Fri May 13, 2022 4:03 am
Rockman
Thanks - found how to do it. Will give it a go over the weekend.
