I reverse engineered the LCD Gear Indicator board as part of my project to build a drop-in replacement for the LCD.  I then proceeded to reverse engineer some other boards and draw their schematics, as well as collected schematics from other sources and re-interpreted those drawings.  The flasher unit schematic is not my work; it is available online.  I'll add more as I convert the BMW OEM circuits into schematic drawings.
GPI  This is the board that is located in the OEM cluster underneath of the Tachometer on the right side, containing the LCD that shows the currently selected gear:
REFERENCE: BMW Instrument Cluster schematics Xfsvnq
REFERENCE: BMW Instrument Cluster schematics 270-041117084711
Large Image
Basic Circuit Description
Power is supplied through pin 15 (+12V) and 31 (Ground).  A diode, V7, ensures that reversing the polarity of the power will not destroy the components on the board.  VIN is fed to the Start Enable circuitry and to the regulator V9.  Regulated VDD supplies the chips with power as well as other parts of the circuit.
The TGPI switch connects to A, B and C inputs.  Diodes, V3, V4 and V5, form a neutral detect feature that operates the Start Enable circuitry.  The three transistors, V8, V9 and V10, creates a +12V signal on the output, LEERL, that drives neutral and the starter relay.  Diodes, V1 and V2, detect when the selected gear is higher than 5th and will send a signal to IC1 to blank the LCD display.  IC1 decodes the inputs and displays a digit on the LCD via PAD-A through PAD-G.
IC2 is an oscillator that creates a high power signal that powers the LCD.  This signal is output on PAD-COM and consists of a 67Hz 100V 50% duty-cycle squarewave.
Speedometer and Odometer
This board is located in the OEM gauge cluster and converts the output from the speed sensor in the final drive into a signal that drives the speedometer servo motor.
REFERENCE: BMW Instrument Cluster schematics 68
REFERENCE: BMW Instrument Cluster schematics 81
REFERENCE: BMW Instrument Cluster schematics 270-191117085105
Large Image
Tachometer
This board is located in the OEM gauge cluster and converts the output from coil #1 into an RPM reading on the tachometer gauge.
REFERENCE: BMW Instrument Cluster schematics 25
REFERENCE: BMW Instrument Cluster schematics 270-161117215844-8181222
Large Image
Early Fuel Level Sensor (4L/7L lights)
This board is located in the OEM gauge cluster for the early K-bikes prior to 1985.  The fuel sensor was a pair of thermistors.  These devices illuminated a lamp in the OEM gauge cluster that showed when the fuel remaining in the tank was 7 litres and 4 litres.  This is an interpretation of a schematic posted by Bert Vogel on K100-forum.
REFERENCE: BMW Instrument Cluster schematics 22810
REFERENCE: BMW Instrument Cluster schematics 270-161117215842-7951388
Large Image
Flasher Unit
This schematic was posted online at the K100-forum and I am including it in this collection.
REFERENCE: BMW Instrument Cluster schematics 14
REFERENCE: BMW Instrument Cluster schematics 270-161117215846-8192362
Large Image
Clock
This schematic is of the clock in the OEM dash.  To test that all segments of the display are working, press both switches together at the same time.
All segments will light up.  When the switches are released, the clock will reset to 1:00.   One complaint of the clock is that it only shows 24 hour time. To get the clock to display 12 hour time, use an Xacto knife to cut the trace at pin 22 (labelled "S5" in the schematic) and then take a 30GA solid wire and join S5 to VIN.  This will change the clock to display hours between 1-12.
REFERENCE: BMW Instrument Cluster schematics 19   REFERENCE: BMW Instrument Cluster schematics 20
REFERENCE: BMW Instrument Cluster schematics 270-211117200828
Large Image
Bulb Monitoring Unit
This board is located in the relay box.  It's purpose is to monitor incandescent bulbs in the rear tail of the motorcycle, the brake light and running lights as well as the brake switches themselves.  If any bulb or any switch is defective, the BMU will illuminate an indicator on the dash. Since there are no parts identification silk screened on the board and my schematic makes reference to part identifiers, I arbitrarily assigned reference numbers to parts on a photo of the board. This photo helps to show the location of the various components and references them by their part identifier on the schematic.
REFERENCE: BMW Instrument Cluster schematics 270-030219185849
REFERENCE: BMW Instrument Cluster schematics 270-270119202315
Large Image
You learn something new every day. I had no idea that you needed an oscillator to drive the LCD. I'd assumed that they were a bit like LEDs; add power and away you go.
Thanks for sharing. This is great work.
Have you ever done one for the speedo amplifier ?
REFERENCE: BMW Instrument Cluster schematics Ir-log10
 ;BMW; K1200RS Red
Ringfad wrote:Thanks for sharing. This is great work.
This is on my TODO list.
fantastic work yet again rob
and thanks for sharing
6Back to top Go down   REFERENCE: BMW Instrument Cluster schematics Empty Instrument schematics Fri Mar 08, 2019 6:36 am
WarrenD
WarrenD
I'm trying to share a link of a drawing I made. e.g.obmacks bits connect. Does this link work?
http://forum.kforum-tech.com/members-upload/uploads/K_Instruments.pdf
ie Can this put in the downloads dept?
I found this but doesn't work?
https://www.k100-forum.com/f3-downloads
I can download with the link provided.
 ;BMW; K1200RS Red
One more post needed, I think.
gabriel
Hi
I have a question about my speedometer. 1984 k100.
Tachometer is working.
Speedometer and odometer not working.
Speedometer became erratic just before it stopped working.
All internal components seem to be ok..
Speedometer face is fine, speedometer needle moves freely on the shaft.
Not certain how to approach this problem.
Incredibly frustrating.
Gabriel.
;BMW; 1984 BMW k100..frame number 6228?
1992 BMW K75s
ivicenzo
ivicenzo
Thanks for sharing, very useful indeed.
I had a problem last year and it took 2 batteries, one alternator rebuilt and some other stuff before unplugging the ABS that was the root of the problem. One pump was defective and it damaged the instrument cluster, battery and alternator. Installed a used one I bought on Ebay but the odometer doesn't work (maybe because it is on miles and my bike is on kms). Anyway, once the ABS was unplugged with the new speedo everything started working. I switched back to the old speedo and it doesn't charge the battery.
Anyway, the 2 questions are: 1. Can the odometer be fixed? 2. Any idea which circuit is responsible for draining the battery? Thanks,
Thanks,
Vin
WarrenD
WarrenD
Check all the connections and the gears. Facebook Ricardo palao for new gear sets.  The alternator needs the charge bulb in the circuit to work. If the bulb is blown it of course will not light nor will it charge.
Exsna01
Exsna01
I will try this also as my speedo is intermittent, thanks much for this help. Lon
WarrenD wrote:Check all the connections and the gears. Facebook Ricardo palao for new gear sets.  The alternator needs the charge bulb in the circuit to work. If the bulb is blown it of course will not light nor will it charge.
This is true with Airheads but not with K bikes, in my experience. There are no idjut lights on Big Block, in fact, no instrument cluster at all, and she cranks out all the voltage juice she needs to keep the battery charged without a bulb (or LED) in the circuit.
15Back to top Go down   REFERENCE: BMW Instrument Cluster schematics Empty Differences to bikes with ABS? Wed Jun 15, 2022 6:08 am
ffbikersa
ffbikersa
I wonder if and which differences exist for bikes with the ABS brakes - K75, K100, K1, K1100?
With weather like we're having here, I'd rather be riding, smelling new-mown hay and feeling G-forces rather than contemplating circuitry but, as it turns out, I must return to stacking firewood. REFERENCE: BMW Instrument Cluster schematics 177381
Anyway, here's a diagram of a K75RT ABS system and a 1993 K1100LT/RS ABS system for comparison. The accuracy of these diagrams is subject to your verification. Laughing
K75RT ABS
REFERENCE: BMW Instrument Cluster schematics Scree187
1993 K1100 LT/RS
REFERENCE: BMW Instrument Cluster schematics Scree188
ffbikersa
ffbikersa
Laitch wrote:With weather like we're having here, I'd rather be riding, smelling new-mown hay and feeling G-forces rather than contemplating circuitry but, as it turns out, I must return to stacking firewood. REFERENCE: BMW Instrument Cluster schematics 177381
K75RT ABS
1993 K1100 LT/RS
Thanks - but I was more interested to find out if there is any difference in instruments  circuitry, save for two ABS bulbs?
No differences in the instrument cluster internals except for the bulbs, as you point out.
