1Back to top Go down   Hard Case Paint Prep Empty Hard Case Paint Prep Mon Apr 25, 2022 6:02 am
zaubertuba
zaubertuba
Getting ready to sand and shoot these case covers when I do the rest of my bodywork.  Is it worth it (and can it be done in a non-damaging way) to pop off the emblem/reflector, de-rivet the latches, and pull off the crash bumpers, or can I get away with good masking?
Hard Case Paint Prep 20220410
1985 K100RS
2Back to top Go down   Hard Case Paint Prep Empty Re: Hard Case Paint Prep Mon Apr 25, 2022 10:42 am
I just do a careful masking job when I do mine.  It's faster than trying to remove all that stuff.
3Back to top Go down   Hard Case Paint Prep Empty Re: Hard Case Paint Prep Mon Apr 25, 2022 10:50 am
The reflector and emblem are held on with double sided tape. Use floss to cut through the tape. Mask the latches as they will be a pain to remove reinstall.
4Back to top Go down   Hard Case Paint Prep Empty Re: Hard Case Paint Prep Mon Apr 25, 2022 12:02 pm
Whichever way you go, make sure you use adhesion promoter.  Cheap insurance to make sure the paint sticks when the plastic flexes.
