1Back to top Go down   Wiring in a new Speedometer Empty Wiring in a new Speedometer Tue Nov 07, 2017 3:42 pm
DBRMN
DBRMN
To start I have a 1991 BMW K100LT ABS
I have purchased the MotoGadget motoscope mini (which comes with its own speed sensor which I don't want to use) which has five wires coming out of it:
Red - Power Supply
Black - Power Supply (Ground)
Yellow - Signal cable of the rev. counter (Leads to the negative pole (clamp 1 or -) at one ignition coil)
White - Connection of the motoscope to the speed sensor (Leads to the signal cable of the OEM speed sensor, or delivered sensor that witched to earth)
Green - cable for the menu push button
Manual:
https://motogadget.com/shop/media/downloads/manual/msm_manual_en_2.3_k.pdf
Now so far I have identified were the Green and Black wire goes lol! and thats it.
I have also identified every wire that comes out of the original instrument cluster:
Wiring in a new Speedometer Instru10
So my questions are, Where is the original instrument cluster getting its main source of power from? Which wire?, Which of the three Tacho related wires is the one i need? (21-23) and If I don't want to use the Speed sensor that goes with the motoscope which wire is the original speed sensor for the original bike?
Thanks,
DBRMN
2Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Tue Nov 07, 2017 9:18 pm
DBRMN wrote:So my questions are, Where is the original instrument cluster getting its main source of power from?
Which wire?
Pin 6 for switched 12 Volts, Pin 1 for unswitched 12 Volts, Pins 13 and 18 are ground returns.
DBRMN wrote:Which of the three Tacho related wires is the one i need? (21-23)
Tachometer input is Pin 16, not any of Pin 21-23.
DBRMN wrote:and If I don't want to use the Speed sensor that goes with the motoscope which wire is the original speed sensor for the original bike?
You can't use the builtin speed sensor on the Motoscope as it stands; It is incompatible.  You'll need either a TGPI v5 board of mine or a Brotbox v3 from Maru Labs to get the job done.
3Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Wed Nov 08, 2017 3:53 am
DBRMN
DBRMN
Which wire?
Thank you so much for your reply! this is so helpful.
4Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 6:11 am
DBRMN
DBRMN
Not sure if anyone will reply to this thread but here I go anyway lol. So I'm looking at the pins for the instrument cluster plug and trying to work out which ones I no longer need. But there is one pin that I don't know the function:
Pin 14: Lamp Monitoring
5Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 6:24 am
Its the output from the Bulb Monitoring Unit.  Goes to an indicator lamp that lights when the  tail light bulb is burnt out. On the ABS models, its also the ABS status light.
6Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 6:26 am
DBRMN
DBRMN
robmack wrote:Its the output from the Bulb Monitoring Unit.  Goes to an indicator lamp that lights when the  tail light bulb is burnt out. Optional.
Wheres that on the instrument cluster though? Wiring in a new Speedometer P1020012
7Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 6:28 am
the red warning triangle
8Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 6:35 am
DBRMN
DBRMN
charlie99 wrote:the red warning triangle
I thought that was Hazards lol
9Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 12:32 pm
BMW use the same symbol on the hazard switch (industry standard), however all four signal lights and both pair of signal indicators on the dash blick when activated.
10Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 1:05 pm
The standard symbol used on hazard switches (also ours) is a double triangle.
11Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 2:57 pm
DBRMN
DBRMN
robmack wrote:BMW use the same symbol on the hazard switch (industry standard), however all four signal lights and both pair of signal indicators on the dash blick when activated.
That was going to be my next question lol I guess I've never tested it out.
12Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Nov 12, 2017 2:57 pm
DBRMN
DBRMN
Inge K. wrote:The standard symbol used on hazard switches (also ours) is a double triangle.
Oh that makes more sense
13Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sat Apr 23, 2022 1:45 pm
ninefourteener
ninefourteener
Hi, I'm reviving this old thread, because I used it to do a motogadget mini installation on my 1990 K100.
Everything "seems" to work correctly. I understand I won't have a speedometer, but I'd hoped to have a tachometer.
When I turn the bike on.... everything "seems" to work correctly.
As soon as I start the engine though..... power is cut entirely from the gauge. Total darkness. No power whatsoever.
Does anyone have any idea what would cause this?
Caviat: I did install an earlier year k100 4-wire ignition switch. The original harness had 5 wires, but after much research, I just didn't use the purple wire, because I read it went to a radio. Bike functions properly, starts, runs, etc.
But now I have this gauge issue.
Thoughts?
1990 K100 Cafe
2017 Indian Chieftain
14Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sat Apr 23, 2022 9:16 pm
You've probably chosen a switched power lead that is controlled by the LSR. Locate a switched power wire on the motorcycle and a suitable ground wire. Be sure to choose a switched power lead that is not disabled by the Load Shed Relay (LSR) on the K-bike. A good source of switched power is Green/Black lead on Fuse #1 available off the "Connector for Special Equipment" located inside the relay box.
15Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Apr 24, 2022 5:56 am
ninefourteener
ninefourteener
robmack wrote:You've probably chosen a switched power lead that is controlled by the LSR. Locate a switched power wire on the motorcycle and a suitable ground wire. Be sure to choose a switched power lead that is not disabled by the Load Shed Relay (LSR) on the K-bike. A good source of switched power is Green/Black lead on Fuse #1 available off the "Connector for Special Equipment" located inside the relay box.
That makes sense.  Hmmmm.
I don't remember if I used pin 1, or pin 6 to power the gauge.
But.... it makes sense that I'd lose power as soon as I started the engine.
Question:  If I switch power to the "other" pin (whichever one I didn't use)..... will I have power to the gauge while the bike is on, but engine NOT running??
2nd question;  If so.... would it be best to splice, and supply power from BOTH pins?
16Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Apr 24, 2022 9:48 am
ninefourteener
ninefourteener
Ok, I'm really at a loss here. This is so frustrating.
The gauge works every time I apply power from:
Red/white wire, pin 1
Green/black wire, pin 6
Grey/blue wire, pin 24
Yes... I even attempted to apply power from the speedometer illumination..... and it works, as long as the headlight switch is on.
BUT AS SOON AS I START THE ENGINE..... all power is lost. All 3 wires..... nothing.
What is going on? This is driving me mad.
1990 K100 Cafe
17Back to top Go down   Wiring in a new Speedometer Empty Re: Wiring in a new Speedometer Sun Apr 24, 2022 1:04 pm
ninefourteener
ninefourteener
I figured it out. Turns out, I grounded the gauge to the low fuel level indicator..... because it's brown with a black stripe.... and not just brown.
Thats what happens when you have a dark garage, and terrible eyesight.
It was working as a "ground" while the bike was on.... but once I started the engine, it shorted out.
All fixed now. Thanks folks.
1990 K100 Cafe
