1 Other speedometer Fri Nov 05, 2021 5:30 am
ouafnico
Hi all !!
Before working on my K100, and cleaning wiring, I am testing the speedometer and the BEP 3.0 I received.
I did not buy a acewell speedo because of the cost, and buy a chinese speedo, technically "standard" to try first :
https://www.ebay.fr/itm/403176386765?hash=item5ddf2f70cd:g:rYkAAOSwSKBdnvgZ
It seems to have the same wiring, 3x3 connector, 3x2 for gears, 1x3 for speedo, but it got 3 standalone cables : red, black, and gray.
I tried to connect the BEP and the speedo, but the colors on cables on the 3x3 are not the same as acewell.
For example, to just power on the speedo, I had to connect :
- green on 3x3 to ground (seems standard)
- standalone black to BATT ! (WTF, why a black cable to 12V positive)
I got working :
- high beam light
- gears (on 2x3 connector)
Not working :
- battery signal
- turning (got problem elsewhere)
I can't test :
- speed and RPM (my K100 don't have oil actually)
I've checked a lot of pictures, schemes, found online, but it seems the colors on the 3x3 are completely messed up.
Anyone with a working speedo can share wiring schemes, others stuff how can help ?
I will put a scheme of what I got
Thanks a lot,
I got working :
- high beam light
Not working :
- battery signal
I can't test :
Thanks a lot,
