1Back to top Go down   Caliper needed Empty Caliper needed Thu May 12, 2022 10:27 pm
fishboy316
fishboy316
Need either a rebuilt rear caliper or a good used one for my 85 K100rs.
 Even a rebuild kit. Any suggestions would be welcome!
2Back to top Go down   Caliper needed Empty Re: Caliper needed Fri May 13, 2022 5:40 am
Woodie
Woodie
Re-building your caliper should be fairly straightforward.  The parts you would need can be found here but there are other suppliers as well.  There might ne a Chris Harris video covering this as well.
Cheers,  Woodie
Caliper needed Logo2111
1985 K100RT  52667
1990 K75RT 6018570 (project)
3Back to top Go down   Caliper needed Empty Re: Caliper needed Fri May 13, 2022 8:27 am
There have been numerous threads about problems with calipers leaking after being rebuilt.  If it was my bike, I would look for a used unit.  There should be no problem finding one.  In my experience, it's the master cylinder that is the weak point in the rear brake.
4Back to top Go down   Caliper needed Empty Re: Caliper needed Mon May 16, 2022 7:44 am
fishboy316
fishboy316
Picked one up on Ebay, $35.
