zaubertuba
zaubertuba
Time always seems to conspire against you---the best laid plans and whatnot.  I'd hoped to get my RS painted and outfitted for work and my regular monthly drives around my district for work last Spring, but time and conditions didn't really materialize until late Summer...and our Summer seemed to short us a bit. :p
Anyway, after reading extensively, and developing a good relationship with our local paint supply shop, I took a stab at doing my own shoot.  There's still some runs and drips (it's a *very* fine line between putting not enough paint on to make a smooth finish and putting too much on), but in the end I was really happy with how it turned out.  Some lessons learned:
-Buy good paint.  It's expensive but worth it.
-The Harbor-Freight paint gun I used was plenty up to the task, but make sure you clean the reservoir strainer *thoroughly*--I ended up ditching it completely when the water-based primer I used didn't clean out totally and conspired to foul my next coat.
-Clean the gun religiously.
-A 21-Gallon Air Compressor is just *barely* large enough for this job. If you're patient.  And it's not too hot.  30 would be better.
-Prep and Sand, Sand, Sand, and when you think you're done sand some more--you can't possibly prep enough!
-I created a "booth" by hanging plastic in my garage.  I vacuumed the space meticulously, left the shop vac running for awhile to try and clean up any "floaters" and dust, and then used the Shop Vac to blow clean fresh air into the booth and create some positive pressure to try and keep dust out.  I *still* ended up with a few drifters here and there but it was wayyyy better than in an "unconditioned" space.  Oh...another good tip, hose down the floor and keep it damp to capture dust and overspray and keep it from kicking back up.  Also, when shooting, between coats, I used the "paintless" first stage of the gun trigger to gently blow off any dust that did happen to show up.
-Degrease and use a tack cloth right before shooting.
-Read the instructions for your paint and clear coats carefully.
-Wear a real respirator--these pro-level solvents are positively *evil!"
-I had one piece in particular that viciously Orange-peeled *twice.*  After the second try, I went, wondering what went wrong, to the paint supplier and he told me "probably not your fault--you don't know what's deep down under those coats" --he said the solvents in the reducer will sometimes draw crap up out of older paint.  He suggested a water-based primer, which I used, and seemed to do the trick.
My "Materials" Table:
Spring Paint Job becomes Winter Overhaul Painta10
Prepared Workspace and parts resanded after a first botched shoot (I didn't prep enough and had some bad sanding swirls still showing):
Spring Paint Job becomes Winter Overhaul Paint110
After the final Clearcoat shoot:
Spring Paint Job becomes Winter Overhaul Paint310
Orange-peel on a re-painted part.   Crying or Very sad
Spring Paint Job becomes Winter Overhaul Paintb10
And here's why--how many coats can you count?  A water-based primer sealed these out and I didn't have a problem on the third shoot for this part.
Spring Paint Job becomes Winter Overhaul Painth10
Mostly together.  The mirrors dripped *badly* so I may reshoot those at a later date, but I'm still pretty happy with how it turned out.  Very Happy
Spring Paint Job becomes Winter Overhaul Paint410
Spring Paint Job becomes Winter Overhaul Paint610
Next up:
-Finding a seat for my '85-->Post '85 cowl change
-installing the Parabellum screen
-Touring bars (the "not actually BMW" C-style bars I'm using will hit the Parabellum shield before full lock), Heated Grips, and Touring Dash cover.
-Rebuild of the Gen II Gas Cap I bought from Cambridge....England (because I bought the gasket kit not remembering my cap was a Gen I)  Embarassed
-Longer control cables (have my throttle and choke cables, just need the center throttle bracket bits and a clutch cable.
-I think a tranny-seal refresh may be in the works, judging by the drips on my garage floor.  Rolling Eyes
So much for riding this (Short) Summer, but hopefully she'll be fully ready in the Spring!  Very Happy
1985 K100RS
Lookin good  that red will make an extra 10mph. Oh and those runs on the mirrors I just use hedge trimmer when it is good and dry. Very Happy
What trans seal are you referring to?
That is a really nice job!  Is that Mystic Red?  That is not a real easy color to shoot due to the flakes in it that are sensitive to gun pressure and coat thickness.
I suspect your bike was repainted some time before you got it.  In my experience, the factory paint is pretty immune to the solvents in aftermarket paint systems.
Orange peel is pretty much guaranteed if you don't use a $300+ pro gun. I always do a 2000 to 2500 grit wet sand and buff with Perfect-it #2 and #3 to get a nice smooth finish.
Rick G wrote:Lookin good  that red will make an extra 10mph. Oh and those runs on the mirrors I just use hedge trimmer when it is good and dry. Very Happy
It depends upon which red. Mystic Red adds 10 MPH. Marrakesh Red adds 8 MPH. Very Happy
It's not so much the size of the compressor in gallons, but how much CFM (cubic feet per minute) it moves. I used to have an HVLP setup (DeVilbiss JGA gun - was their top of the line back then) when I was doing mostly custom stuff and I know from experience that a continuous 11.0 CFM at 40 psi is the minimum you need for a successful lay-on with the JGA. I stilll see 8 CFM at 40 psi recommended but that's pushing the lower end and pushing it hard. I also used to reckon on using a full reservoir of thinners to clean the gun between colour chnages. As you found out, you also need some form of barrier coat if overpainting old stuff. I prefer to rip all the existing paint off, if only to see if there's any damage underneath that needs patching first but admittedly, that is a habit gained from having other people pay me to paint their bikes. Finally, as you also found out, a good VOC (volatile organic compound) mask is a life-saving necessity. Double-filter is best.
Having said all that, that's a really good job you've done there! Spring Paint Job becomes Winter Overhaul 212902
Some comments on the Harbor Freight "purple" "HVLP" gun.
The purple Harbor Freight gun is okay, the atomizing and pattern aren't too bad (there's a bit of dry spray at the edges of the fan), but you have to control the leaks.  I consider it a "one job" gun that I toss when I'm done.
The early ones had a nasty habit of leaking where the reservoir joined the gun's body and a bunch of air leaks.  They seem to have sort of solved that problem, but the one I bought sprung a leak in the packing around the needle between the trigger and the nozzle.
Last spring I painted the hull of my 32 foot sailboat with a new HF purple gun.  I carefully prepped the gun by cleaning out all the silicone caulk they use at the factory and putting teflon tape on all the air leaks.  I even went in and tightened up the packing to where it barely dragged on the needle.
After shooting about 4 quarts of base and 1 quart of clear the packing started to leak.  Since it wasn't dripping onto the hull I decided to keep going because I really couldn't stop to clean, disassemble, tighten, and reassemble the gun because I had to keep building the clear.  At the end, I would estimate that about 10% of the clear coat was leaking out onto my hand.  What a mess!
zaubertuba
zaubertuba
duck wrote:What trans seal are you referring to?
Well I'm getting a tranny fluid drip from the bottom of the housing.  I was actually figuring, if I'm pulling the tranny anyway I might as well do a complete seal kit on the darned thing.
1985 K100RS
zaubertuba
zaubertuba
Point-Seven-five wrote:That is a really nice job!  Is that Mystic Red?  That is not a real easy color to shoot due to the flakes in it that are sensitive to gun pressure and coat thickness.
I have to confess, that's actually a VW OEM color.  I was really particular about the tone I wanted and probably looked at about 30 chips out in the sun in front of the paint shop before I settled on one--I'm glad I took that time!
This paint had "pearls" instead of metalflake.  From what I've heard it's a little more forgiving.
You're probably right about the repainting--but those parts came from four separate bikes, so that's probably why I had the problem with *just* that side cover, lol!
1985 K100RS
zaubertuba
zaubertuba
Dai wrote:It's not so much the size of the compressor in gallons, but how much CFM (cubic feet per minute) it moves. I used to have an HVLP setup (DeVilbiss JGA gun - was their top of the line back then) when I was doing mostly custom stuff and I know from experience that a continuous 11.0 CFM at 40 psi is the minimum you need for a successful lay-on with the JGA. I stilll see 8 CFM at 40 psi recommended but that's pushing the lower end and pushing it hard. I also used to reckon on using a full reservoir of thinners to clean the gun between colour chnages. As you found out, you also need some form of barrier coat if overpainting old stuff. I prefer to rip all the existing paint off, if only to see if there's any damage underneath that needs patching first but admittedly, that is a habit gained from having other people pay me to paint their bikes. Finally, as you also found out, a good VOC (volatile organic compound) mask is a life-saving necessity. Double-filter is best.
Having said all that, that's a really good job you'vedone there! Spring Paint Job becomes Winter Overhaul 212902
Good point on the CFM--and I actually did check that on both the gun and compressor before I bought them.
On the longer shoots, I actually flushed the gun every time I had to mix a new batch of paint for the reservoir.  Maybe that's overkill but I'm not an expert and I was taking a bit long on mixing each batch, lol.
I debated stripping that one part all the way down, but I also had the bags to do which I know *had* been repainted at least once, and was running short of time.  One of these days, I'll have a shop that I don't have to revert to housing the Wife's car during the week!  Laughing
1985 K100RS
zaubertuba
zaubertuba
Point-Seven-five wrote:Some comments on the Harbor Freight "purple" "HVLP" gun...
That's indeed the gun I used, and I kind of gathered it may not have a long production life, lol.  But I seemed to be lucky and didn't get any leaks/issues on this (relatively short) shoot.
They had a better gun at the pro shop I was at.  If I end up doing more painting I might look at that, but as a "throw-away" gun the HF gun did pretty well.
1985 K100RS
Dai wrote:Having said all that, that's a really good job you've done there! Spring Paint Job becomes Winter Overhaul 212902
Spring Paint Job becomes Winter Overhaul 112350
The reason I ask is that there's a small seal at the back end of the clutch pushrod that can leak. Gear oil then travels up the pushrod "pipe" in the center of the input shaft and comes out at the bellhousing weep hole. I had this happen on one of my Ks.
When you pull the tranny check to see if the clutch pushrod has any gear oil on it or in the "pipe."
#12 in this diagram:
https://www.realoem.com/bmw/enUS/showparts?id=0511-USA---K589-BMW-K%20100%2083%20(0501,0511)&diagId=23_1155
It's a PITA to remove. I screwed up the first one replacing it. On the second one I used a small socket (same diameter as the seal) to drift the seal in and that worked really well.
zaubertuba
zaubertuba
duck wrote:When you pull the tranny check to see if the clutch pushrod has any gear oil on it or in the "pipe."...
Ooh that's great advice!  Thank you I'll make a point of checking that when I go in.   Very Happy
The reason that shaft seal is so hard to get out is that it has a metal collar that you need to pry out. I can't remember exactly how I got it out, just that is was extremely frustrating.
I did this a LONG time ago. If I were doing it today I'd probably be smarter and put the new seal in the freezer overnight to shrink it a bit in the hope that it goes in a little easier.
zaubertuba
zaubertuba
Added:
Spring Paint Job becomes Winter Overhaul 20230112
-Parabellum windscreen. Our local True Value is a Godsend--There's never been a fastener I have not been able to find there that I can never seem to find at the big box hardware stores.   I still need to fabricate some straps to secure the bottom of the Fairing extension, though.
-Touring bars (now my Master cylinder won't hit the Parabellum at full steering lock, lol).
-My dearly departed Father-in-Law, Bless his Soul, kept *everything*...including a pair of 70mm BMW emblems.  Very Happy
-New set of Odometer Gears to replace the failing stock set.
On the way:
-New Tripmeter and Low Gas Light bulb holder, courtesy of Point-Seven-Five (thanks so much!)  Very Happy
-Overhauled MK II Gas cap.
-Choke (Enricher), Throttle and Clutch cables to match the Touring bars.
-Seat to fit the Post-'85 Cowl
Still To Do:
Since I have family in Spokane and visit Post Falls for work monthly, I'm going to pull the injectors and drop them by Mr. Injector (he's just down the road in Coeur D'Alene) on my next visit.
Probably high time I replaced the Fuel Filter.
RT/LT Dash Panel (The RS panel really doesn't work well with RT Bars).
Auxiliary LED Driving lights.
Oxford Heated Grips.
Givi Trunk with Brake lighting...or maybe just a lighted helmet?  I have a nice BMW Tankbag set and I *think* I can travel with my work laptop bag in one side case and my clothes in the other case and the tankbag, so I might not actually *need* more luggage space, but I would like better braking illumination, either way.  Cool
Oh yeah, and almost forgot--that Tranny Seal.
1985 K100RS
No. Try to find a set of grips with a rotary switch on them. The Oxfords only have four heating positions (at most, not including off. Some have only three). The rotary switch type gives a much finer control of the heat output (and it is a switch, not a potentiometer. You can feel the clicks as you rotate it).
e.g.
https://www.ebay.co.uk/itm/193724907385?epid=24033696718&hash=item2d1ae77f79:g:rQMAAOSw6Hdflr4h&amdata=enc%3AAQAHAAAA8PHIYzzUY0afPYDZIl4jI80NAkyh9501WM%2BTsKucgeNGqn%2B%2FeKgOOLo837UobbakB%2F4uJ7492RDTKKjYIOqopFHxWpAjKdsR9DrgaY%2BQbXFa3e%2BK3fslCwsOClfi07hhfnfTmkTDd3gQcNnolZiUarZ90d7vAYxDfaFHVX2D4EejePzOKkYqVDzjQ3FjJbes7o1UDqq69z%2B1rzsyr8HQF1MpVLzMKoWpf3ZrocJMOxmLZNAzO%2FDejw1JDAB9ExA8A7r8vIaidRJWrL9%2FsaCPPrc1uYmWoqm8%2FotbrlUbWH13CO3SikrvpiR6chYDncNkQw%3D%3D%7Ctkp%3ABk9SR6jFgMK7YQ
zaubertuba
zaubertuba
Dai wrote:> Oxford Heated Grips.
e.g....
Yeah, honestly I'm not a big fan of strapping any of those little control boxes to the handlebars.  I'd much rather wire in a knob installed in the dash panel.
Maybe not as fine an adjustment, but at least there's 5 settings--anyone have any experience with these?...
https://www.cyclegear.com/parts/koso-apollo-heated-grips?sku_id=1176958
1985 K100RS
zaubertuba
zaubertuba
Got all the bodywork attached--happy with how the cockpit's turned out!
Spring Paint Job becomes Winter Overhaul 20230411
Spring Paint Job becomes Winter Overhaul 20230410
And yeah, I broke down and got the Oxfords.  Mounting the control box wasn't as bad as I thought, but OMG the the work it took to get the throttle-side grip to fit without squeezing the throttle sleeve too hard!   Rolling Eyes
1985 K100RS
JiiPee63
JiiPee63
zaubertuba wrote:Maybe not as fine an adjustment, but at least there's 5 settings--anyone have any experience with these?...
Hi there,
I installed similar heated grips (Koso HG-13) on my brick during the winter. I don't want extra control boxes for the handlebar either. Haven't ridden them yet as the bike is still winterizing in my garage. According to weather forecast, I might be able to have a ride this weekend as the temperatures will be around 10 degrees celsius.
What made me to have those grips? One year ago, at the end of April, I was riding towards the city of Lahti. The temperature was 2-3 degrees celsius. After about 50-60 kilometers, I had to stop to warm up as my fingers were deep frozen despite the winter driving gloves. That's when I decided that I don't have to suffer anymore. Other reasons are sleek design, almost plug&play installation and recommendations.
I am waiting eager to have them tested.
Spring Paint Job becomes Winter Overhaul Koso_h10
Last edited by JiiPee63 on Fri Apr 07, 2023 3:10 am; edited 1 time in total (Reason for editing : Added some text)
1986 K100RS 0089906 (Red)
2008 HD Electra Glide Ultra Classic (pearl white&black)
Ex - 1984 K100RS (white), 1986 Suzuki GR650
JiiPee63
JiiPee63
zaubertuba wrote:Got all the bodywork attached--happy with how the cockpit's turned out!
 Looks beautiful, good work!!! Spring Paint Job becomes Winter Overhaul 112350
firstle
firstle
i dont like the heated grips to much , why have a hot palm , i use the heated gloves and the heating element runs down the back of the fingers and top side of thumb , under bar muffs my hands have never been cold under some bad conditions , dragon rally each year , only problem being im not sure they sell them any more and after 30 plus years mine are looking tatty  Sad
firstle wrote:i use the heated gloves . . . under bar muffs . . . im not sure they sell them any more
I use bar mitts, too, and electric gloves heated by 12V supplied by a cable from the Brick's power socket. It has a rheostat.  Battery-powered and 12V gloves are still being made; this lineup has a few. Smile
Bike looks really good!  Is that Mystic Red?  Looks good on the RS.
