1 Repair Hi/Lo beam switch Thu Oct 22, 2020 4:08 pm
waneill
Another way to repair the Hi/Lo switch after taking it apart is to use a dremmel like tool to carefully grind out the plastic housing around all of the electrical contacts. Harbor Freight sells a Dremmel like took for a little over $10 that comes with many small cutting tools. One of these tools is a small bur about 3 mm in diameter. This tool works well to grind the switch housing. I found that grinding about 0.010 inches or 1/4 mm works well. This method avoids melting the plastic and pushing the contacts in further.
I live in Montclair, CA and would be happy to assist anyone repair their switch.
