1Back to top Go down   Brake Pipes Empty Brake Pipes Wed Mar 02, 2022 12:49 pm
giuzzo
giuzzo
Hi, I need to replace the two little front brake pipes (left/right) of my k100 (part numbers 34 32 1 450 757/34 32 1 450 758) and the grommets (34 32 1 236 462). Unfortunately they told me that they are currently out of stock. Any idea where can I find them? Thanks in advance. Bye
Brake Pipes K100_f13Brake Pipes K100_f12
2Back to top Go down   Brake Pipes Empty Re: Brake Pipes Wed Mar 02, 2022 4:02 pm
A good brake specialist should be able to make the pipes and hoses if needed. You might have to do a bit of searching. Try contacting vintage car or motorcycle clubs they should be also able to help you find a specialist.
3Back to top Go down   Brake Pipes Empty Re: Brake Pipes Thu Mar 03, 2022 1:11 am
Those pipes are currently listed in stock at Motorworks in the UK. See the links below to the website for each pipe.
Left pipe
Right pipe
4Back to top Go down   Brake Pipes Empty Re: Brake Pipes Thu Mar 03, 2022 6:48 am
giuzzo
giuzzo
Thanks both of you for your kind reply. :-)
