1Back to top Go down   Frame straightening Empty Frame straightening Tue Mar 01, 2011 9:33 am
chrish8846
One of my K bikes was hit slightly in the dr side saddle bag and has tweeked the rear frame section slightly. Anyway to easily or to work at it way to correct this without replacing the frame and it's attendent title problems??
2Back to top Go down   Frame straightening Empty Re: Frame straightening Tue Mar 01, 2011 11:33 am
Chris,
The only important alignment on the rear frame is the part where the shock attach to. The swing arm is part of the engine/gear box assembly and its not affected by the rear part of the frame. The rear frame is only a support for the saddle and the cowl.
If the top of your rear frame is slightly bent, it will only reflect on your sitting position.
Hope you don't have one arm longer than the other Very Happy
Frame straightening Frog15Frame straightening Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Frame straightening Empty Re: Frame straightening Tue Mar 01, 2011 12:09 pm
chrish8846
Thanks for the reply, the stock mount is offset slightly to the pass side.
Chris Hammond
1985 K100 RT sold
1992 K75RT still in Fixing mode
4Back to top Go down   Frame straightening Empty Re: Frame straightening Tue Mar 01, 2011 1:17 pm
I believe that as long as the shock is not binding, you are OK.
5Back to top Go down   Frame straightening Empty Re: Frame straightening Tue Mar 01, 2011 2:06 pm
chrish8846
Chris Hammond
1985 K100 RT sold
