1Back to top Go down   K clutch arm pivot bearing removal Empty K clutch arm pivot bearing removal Sun Jan 23, 2022 2:08 pm
attitude
attitude
Removed those little needle bearings by getting small bead on shell and tapping out with a punch.  No luck with blind puller or any other method.
Just very low current on wire feed welder and a delicate touch. K clutch arm pivot bearing removal 20220110
While you have it out is a good time to fit a grease nipple. The occasional greasing keeps the road crap out.
K clutch arm pivot bearing removal Clutch25
