Jonas Bodin
Jonas Bodin
Hello!
I'm changing the original cluster for an aftermarket "all in one"-speedometer.
My first question is if the lamp monitoring needs to be connected to anything? I don't feel the need of the luxury of lamp monitoring but of course want the bike to work properly  Cool
The second question is if the cancel relay signal (blue/green, no21) needs to be connected? I'm guessing it has something to do with the automatic cancelling of the turn signals? Doesn't feel the need of this luxury either, but again want's to know if it will affect the bike in any way to just leave it out?
Third and last I wonder if it's possible to use the speedometer illumination (grey/blue, no24) as a +12V source to indicate that the lights are on? I.e. will there be +12V on this cable when the lights are turned on? (And no feed when the lights are off?)
/Jonas
BobT
BobT
The Bulb monitoring unit can be completely bypassed, something that you need to do when you fit LED rear light bulbs. The diagram for doing it is on this forum somewhere as it has been covered many times. Mine has been eliminated and has been working fine for years now.
Jonas Bodin
Jonas Bodin
Lamp monitoring, cancel relay and speedometer illumination Img_0114
This may be simpler to follow.
Remove the BMU and insert jumper wires as per the diagram below. You'll just need some spade connectors from an auto or electronics store to crimp on the ends.
Don't throw the BMU away. Pass it on to someone in need or sell it on ebay.
Lamp monitoring, cancel relay and speedometer illumination Bmu11
Jonas Bodin wrote:Third and last I wonder if it's possible to use the speedometer illumination (grey/blue, no24) as a +12V source to indicate that the lights are on? I.e. will there be +12V on this cable when the lights are turned on? (And no feed when the lights are off?)
Yes. Instrument lights are switched off the main R/H light switch. In some parts of the world (like the US) this switch was later removed and lights remained on all the time. All later (16v ??) K-bikes were the same.
IMO tho... its very annoying to have a dash light glaring in your eyes constantly while you're riding at night and it can affect your vision of the road ahead. The instrument lights are just a dim glow. I would leave it out.
 Lamp monitoring, cancel relay and speedometer illumination Austra12    Fuel:  95 Octane
Jonas Bodin
Jonas Bodin
Holister wrote:This may be simpler to follow.
Thank's for your help!
Getting closer to sorting the Electrics out Smile
6Back to top Go down   Lamp monitoring, cancel relay and speedometer illumination Empty bmu eliminated still no brake lights Tue Dec 28, 2021 8:35 pm
Spexbike
Spexbike
Hi there Peeps,
85 K100rs,I converted all my lights to led a while ago,modified the blinker relay and everything worked as it should.
The rear is an all in one brake/tail/license plate light.
I got new rear sets, including a new rear brake master cylinder with integrated reservoir and a pressure switch.
Before I switched to the new master cylinder and pressure switch the front and rear brake light worked fine,now neither brake light works.
- I tried 2 different pressure switches
- All the blinkers,headlight and tail light work, but no break lights !
- I eliminated the bmu as described in this thread,thinking it would do the trick,but no.
- I do get current to the E2 grey/green wire/plug when rear brake is pressed.
- I have continuity between the main ground under the tank and the ground at the gear box.
- cleaned the grounds anyways and put a bit of electro grease on contacts.
- When I press the front or rear brake, the license plate light gets a tad bid brighter.
- wiggled the wires from tail light to the harness a bit,no difference.
Any advice before I set it on fire and push it off the next cliff?
Much appreciate any good ideas,THX
http://www.spextattoo.com/
No need to post the same message in two places the same people see it when it comes up as a new post
Admin
Spexbike
Spexbike
RicK G wrote:No need to post the same message in two places the same people see it when it comes up as a new post
Admin
Sorry,just trying to get an answer,thx for the heads up
Sounds like a cafe racer, but okay, I'll bite.
Does the brake light work if you disconnect the rear brake pressure switch?  That would essentially put you back to where you were before you started having the problem.
If it does, then the problem is in the wiring of the rear brake pressure switch.
If you still have a problem, you must have disturbed the wiring at your all -in-one brake-tail -license light unit.  Get the front brake switch working then go back and reconnect the rear switch to see if things work.
Not knowing what you did to remove the BMU, I'm at a disadvantage as to really understanding where you need to look for the problem.
10Back to top Go down   Lamp monitoring, cancel relay and speedometer illumination Empty Bmu Wed Dec 29, 2021 4:02 am
daveyson
daveyson
Some other stuff to try. I'll guess you have a jumper wire from e1, e2 and 54a. I'd remove it and put a jumper wire from e2 to 54a (rear brake pedal to brake light) Then the light should work with the pedal pressed. Then remove it from e2 and place it in e1 (front brake to brake light) to see if that works.
Since both front and rear don't work, and the license plate light gets brighter, I'm thinking about a bad earth. With a test light clip on battery positive and probe to brake light earth, the test light should glow. Then the other way around it should glow with a brake lever pressed.
If the globe is getting power and earth but not working, you want another globe.
 ~120,000 km
acftfliehr
acftfliehr
All, I like the idea of making Jumpers for this....  So simple and effectively clean without going through the act of with disruption at the connector level..
I started to look at both diagrams and compared the verbage of the original diagram with the present and it seems to have to be rotated to make sense side by side...
See if this is a better comparison with both....
http://forum.kforum-tech.com/members-upload/uploads/BMU_Bypass_w_Jumpers.pdf
http://forum.kforum-tech.com/members-upload/uploads/BMU_Bypass.pdf
