1Back to top Go down   Gear lever removal Empty Gear lever removal Mon Nov 15, 2021 6:17 am
tinyspuds
tinyspuds
Not the sophisticated solution you're used to, but it worked so I'll share. With a LH chair all ops on that side tend to be more difficult, but I think this tool might be generally useful even on a solo. I needed my gear lever off so that I could re-position it for my bulky winter boots, but it resisted all attempts to wiggle it off and I didn't want to put a metal lever against the seal. This wooden taper sat between the gear box and lever working around the shaft took just a couple of taps on the top end. It is a bit Flintstones but it worked like a charm. Gear lever removal Img_2025
2Back to top Go down   Gear lever removal Empty Re: Gear lever removal Mon Nov 15, 2021 11:05 am
Shep
Shep
Are there any threads out there that address the bulky boot gear leaver position?
I find getting my my new boot firmly positioned underneath the gear lever and in towards the frame not as comfortable as I would like it to be.
3Back to top Go down   Gear lever removal Empty Re: Gear lever removal Mon Nov 15, 2021 11:10 am
tinyspuds
tinyspuds
Shep, i’m looking at a cam arrangement that will let me switch between Summer/Winter boots. But the immediate issue for me is solved, so that’s back burnered
4Back to top Go down   Gear lever removal Empty Re: Gear lever removal Tue Nov 23, 2021 12:05 pm
schrocketeer
schrocketeer
Car battery terminal removers can be used as gearshift lever removal tools. They're relatively cheap, readily available, and there's enough metal on the lips of the jaws to get underneath the shaft and pull straight out.
Any kind of wedge I've used on a gear shift lever requires you to move the wedge from side to side, to pull evenly.
Ken
85 K100RT
91 XR250
97 XR100
70 CT70
06 YFM400
Past Bikes:
95 VLX600
86 TRX250
02 GZ250
83 Z50R
78 ATC90
86 XR250
79 XR500
72 AT1
75 YZ360
78 DT400
75 DT125
73 Trail 70
Dad's bikes I rode in high school
69 CL175K3 Scrambler
71 R5-B (RD350 predecessor)
5Back to top Go down   Gear lever removal Empty Re: Gear lever removal Tue Nov 23, 2021 1:04 pm
tinyspuds
tinyspuds
Great tip Ken, thanks.
Stu
