1Back to top Go down   Snowflake in K100 2v front end  Empty Snowflake in K100 2v front end Mon Jul 26, 2021 6:37 am
AussieDan
AussieDan
Hi all,
Has anyone tried to fit a snowflake front wheel in a K?
I am putting my old K front end into my R65 and want to keep the snowflake wheel.
2Back to top Go down   Snowflake in K100 2v front end  Empty Re: Snowflake in K100 2v front end Mon Jul 26, 2021 12:44 pm
AussieDan wrote:Hi all,
The axle diametre is much smaller (17mm) on a Type 248 Airhead, by far, than the average K bike (25mm), starting with bearing I.D. Then there's the axle spacers that'll need to fabbed up by your favourite machinist to get the spacing correct. Then there's proper disc brake alignment...not to mention diametre again as most R65 discs are 260mm (and five bolt) as compared to 285mm (and four bolt) on a K. There's also the spacing for calliper mounting if attempting to use the older Brembos (or oddball R65 ATE) from the R65 on the K forks. But that shouldn't stop you. Let the fun begin.
3Back to top Go down   Snowflake in K100 2v front end  Empty Re: Snowflake in K100 2v front end Mon Jul 26, 2021 5:21 pm
Shep
Shep
Snowflake in K100 2v front end  Dsc04410
I this what you  mean by a snowflake wheel? Is it not the standard K100 RS wheel?
Shep
Snowflake in K100 2v front end  Dsc04413
Last edited by Shep on Mon Jul 26, 2021 5:36 pm; edited 1 time in total (Reason for editing : Figured out how to insert proper size of picture.)
4Back to top Go down   Snowflake in K100 2v front end  Empty Re: Snowflake in K100 2v front end Mon Jul 26, 2021 5:47 pm
The images above show a Y spoke wheel. Snowflakes were fitted to 1977 on Airheads, tho' I do note some refer to K bike Y spokers as snowflake wheels. The original poster specifies R65 which had snowflake wheels like the versions below.
Snowflake in K100 2v front end  Jjimi810
