1Back to top Go down   larger rear brake disc Empty larger rear brake disc Tue Sep 21, 2021 8:49 pm
arbalest
I am working out the details of this arrangement. So, the rear disc will now be the front disc. Is there any such thing as a larger brake disc, or how would I modify a larger disc to fit the final drive?
2Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Tue Sep 21, 2021 10:35 pm
Might be an idea to mention the bike...
3Back to top Go down   larger rear brake disc Empty larger disc Wed Sep 22, 2021 10:39 pm
arbalest
92KK 84WW Olaf wrote:Might be an idea to mention the bike...
I want to use a K100 swingarm and final drive (with pinion removed) as the swingarm on a leading link fork.
4Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Wed Sep 29, 2021 8:59 pm
Sounds like you like to fudge things a bit. you could try using a four piston brake unit on the stock disc for alittle more pressure and stopping power but you have to go to an equivalent master to match that. Going up in size means shifting the calliper up closer to the wheel, that limitation would set you with perhaps little more than a K1100 front disc and calliper. You have to strip the rear disc housing and machine the front K1100 housing to go in place of the old K100 disc on that old housing. Stock mono was 285 and the K1100 front is 305 it may fit.
Just edited that disc size to what it should be, Taa TWB
5Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Wed Sep 29, 2021 10:12 pm
Been thinking about this. A lot more stresses on that mounting stud up front ......assuming you mean using a Monolever and not a Paralever.
6Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Wed Sep 29, 2021 10:36 pm
K1100 front discs are 305mm.
7Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Thu Sep 30, 2021 1:06 pm
gorio
Is the bigger disk to capture some sort of look?
Once the weight transfer happens and you can start some serious front braking the back brake doesn't really need to be very powerful to lock the wheel. If you can lock the wheel why add more braking?
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
1982 Kawasaki 750GPZ
1975 Norton 850 Commando
8Back to top Go down   larger rear brake disc Empty K final drive larger brake disc Thu Sep 30, 2021 5:50 pm
arbalest
gorio wrote:Is the bigger disk to capture some sort of look?
Per previous posts here, the final drive (along with the swingarm) would be used as the swingarm on a leading link front end. The point of the larger disc is to get more swept braking surface, with 4 or 6 pot calipers to get some serious braking for my sidecar rig.
9Back to top Go down   larger rear brake disc Empty Re: larger rear brake disc Thu Sep 30, 2021 6:12 pm
gorio
guessing I should have read more carefully.
1992 K100rs 16v
1997 R1100rt
2006 R1200rt
Past lives
Kawasaki Concours
1976 BMW R90s
1975 Ducati 860gt
1992 Honda VFR750
1985 Honda VF750
