1 Are water/oil pump with two sensors only for California bikes? Tue Aug 24, 2021 12:59 pm
bmwk100rs
It's neither. The rubber boot covered switch indicated by the upper arrow is the oil pressure switch connected to the oil pressure light in the instrument cluster.bmwk100rs wrote:Mine has another sensor instead of drain plug. Is that a normal or is it California thing.
Laitch wrote:The rubber boot covered switch indicated by the upper arrow is the oil pressure switch connected to the oil pressure light in the instrument cluster.
The lower arrow points to a water temperature switch that would connect to a temperature gauge on the fairing interior, if your moto had one.
K100-forum.com » Technical, repair and troubleshooting » Engine and transmission » Are water/oil pump with two sensors only for California bikes?
Similar topics
