1Back to top Go down   trip meter knob re-assembly Empty trip meter knob re-assembly Sat Aug 14, 2021 3:22 am
tinyspuds
tinyspuds
The trip meter knob consists of:
knob
washer
spring
washer
circlip
If the circlip comes free (probably because of not fully retracting the knob when taking out the instrument panel  Embarassed ) the circlip, last washer and spring will ricochet around inside the cluster housing. The circlip is very small (7 maybe 6 mm) and attempting to reassemble everything in situ is a great example of ‘doing the same thing and expecting a different outcome’.
trip meter knob re-assembly 17ee7310
The reset shaft enters the binnacle through a plastic bush which is held in place by flexible teeth
trip meter knob re-assembly 6febba10
If these teeth are prised gently inwards, the bush can be pressed out then bush, knob and components are easily assembled outside the housing.
Don’t be like Stu.
