1 Aftermarket Turn Signal Stays On, but can hear blinker working Sat Aug 21, 2021 7:32 pm
JamesU
I have a 1985 K100RT. The fairing is removed, and I am installing aftermarket LED front turn signals. I have disconnected the Hyperflash already. Pretty straightforward installation, but the bike turn signal is a 2-wire setup, while the new turn signals have a 3-wire setup and include a DRL wire. After installing without the DRL wire connected, the right turn signal stays on and does not blink, however I can hear the blinker working. The other side works fine, blinks and cancels, timing looks normal. I switched the turn signals to see if it would do the same thing on the other side and same thing happened. And I should also mention that the rear lights and Speedo are currently disassembled.
Does it seem like it is an issue with the “cheap” Amazon blinker having the turn signal wire crossed with the DRL, or am I missing something with a flasher relay or fuse?
