1 update on the fuel pump saga Sun Jul 25, 2021 10:46 pm
Spexbike
this is 1985 k100 rs. The bike ran about a week ago when I still had overheating problems.I got a new coolant sensor,new thermostat, a used cooling relay,removed the vacuum sensor and plugged the barb on cyl 1 on the throttle body.Bike cranks over but won't fire up w.No fuel getting to the fuel rail.open the tank ,took the fuel hose that goes to the top of the pump off the filter,pushed start... at this time I should have fuel squirting out of the hose,correct? but nothing.It's a new pump,it worked before. Even put the old cooling relay back in to make sure that is not the issue,but that shouldn't even have anything to do with the fuel pump,
I checked all the fuses and turns out I don't get any power to the fuel pump fuse (fuse6),but I have power to the 4 pin plug,how does that make any sense? I checked the back of the fuse panel and it all looks fine.
fuse1 12.88V
Fuse2 6.5
Fuse3 11.66
Fuse4 0V
Fuse5 0V
Fuse6 0V
Fuse7 7.5V
4pin plug to tank:
green/white-brown/black 10.98V
green/white-brown/white 10.97V
green/white-brown 10.87
green/white-2nd brown 0.0V
This is with ignition turned on ,battery is holding a charge 12,7 V
I thought I was gonna jump the pump (just for a second to see if it is running)
from right side of fuse 4 to left side fuse 6,but since I didn't have any power on the fuse locations,I didn't even try.
Put everything together after I pulled the fuel pump relay to inspect and clean contacts,pushed start 3-4 times and nothing,couldn't hear the new pump kicking in ,any advice is greatly appreciated,anyone savvy with this stuff? THANX A Bunch
fuse1 12.88V
Fuse2 6.5
Fuse3 11.66
Fuse4 0V
Fuse5 0V
Fuse6 0V
Fuse7 7.5V
4pin plug to tank:
