1 Gear indicator switch Sun Oct 12, 2008 10:53 pm
Morley
Hello,
I'm new here but not to BMW's. I currently own a 2002 K1200LT. I was asked by a co-worker to "fix" his 85 K100RT..little did I know. He dropped the bike off and it was a total basket case. It had sat for 7-8 years WITH gas in it and at least 2 of the last years were outside. I have successfully ressurected the bike with the exception of the gear indicator. 1st gear and neutral read correctly, the others do not. 2nd gear shows 0 and usually the neutral light comes on, dimly at irst then it gets brighter. 3rd shows 1, 4th shows 0 and 5th shows 1. It also had an inop speedometer which I was able to fix by opening the cluster and cleaning all of the male & female pins inside (crappy design/construction) The gear indicator got "better" a bit, 5th used to say 1, 5, 8, 9 then back to 1. Now it just says 1. I rang out (ohmed) the switch first and it all checked good (of course sometimes the indicator reads right too) then went into the cluster. It seems I'm back to the switch...My question is; can the switch be removed with the engine/trans still "installed" in the bike? I've seen the pics of the switch disassembly & cleaning but not how to remove it. And is there anything in the trans where it mounts that has to be aligned when re-installing it?
Another question on another subject. I see where the 85's output shaft has problems with only having 6 rivits holding the gear to the shaft. I know everyone just looks for another used newer engine when they find the rivits loose or broken...But has anyone ever tried to re-shoot rivits in it and maybe add another 6? I work as an aircraft mechanic (with a structural repair background) and can get monel steel rivits in any size needed and was just wondering about the feasibility of doing a repair of that kind. Since you'd already have the engine open to confirm the broken/loose rivits...what is there to loose?
Thanks for any answers/advice you may have to impart.
