1Back to top Go down   Simple auxiliary wiring diagrams Empty Simple auxiliary wiring diagrams Sun Feb 13, 2022 10:43 am
After the couple of topics doing the rounds here recently, one on fitting aftermarket heated grips and one on fitting additional lights, I've brewed up the simplest diagrams I could come up with. Both use the alarm connector as the power source; the heated grips one does not touch the existing loom at all and the driving lights one just requires a feed from the high beam (white) wire as a control. As they use the alarm connector, both are fused though fuse 5.
http://forum.kforum-tech.com/members-upload/uploads/aux_circuits.pdf
-Dai
2Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Mon Feb 14, 2022 8:06 am
Updated with a third circuit if running dual filament halogen aux lights (or two fog and two spot lights). Update mainly aimed at LT and RT owners with the 50-amp 'police' alternators.
http://forum.kforum-tech.com/members-upload/uploads/aux_circuits_v2.pdf
3Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Tue Feb 15, 2022 10:52 am
Curley
Curley
thanks for that. Perfect timing as i am planning to add additional lights soon!!!
Simple auxiliary wiring diagrams Ir-log11Simple auxiliary wiring diagrams Ir-log11Simple auxiliary wiring diagrams Ir-log11Simple auxiliary wiring diagrams Ir-log11Simple auxiliary wiring diagrams Ir-log11
cheers  White K100RS 1991  cheers Red K1100LT SE 1995 cheers Green K75RT 1995 cheers Black K75s 1987  cheers
4Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Tue Feb 15, 2022 7:09 pm
If you're not sure about something Curley, just give us a shout.
5Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Tue Feb 15, 2022 7:31 pm
If you are thinking of using the the alarm connection then this little chappie from Tills may be what you are after The K Cable.
I'll grab a couple on my next order with them.
6Back to top Go down   Simple auxiliary wiring diagrams Empty K Cable Thu Feb 17, 2022 7:32 pm
Packo
Packo
Does anyone have an alternate supplier for the plug used in the "Tills K Cable" please ???
I went to order one from Tills and the freight to Aust was $40 euro
I guess that the plug is used commercially in numerous applications but I have no idea where to find it.
Simple auxiliary wiring diagrams K_cabl10
______________
83 K100 HRD Outfit
1992 K1100 Outfit
2003 R1150 GSA Outfit
1983 K100 Basic
7Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Thu Feb 17, 2022 9:37 pm
Packo,
I can throw an extra one in my next order if you like.
8Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Thu Feb 17, 2022 11:41 pm
At that price Packo I think I would look at popping the pins out of that white plastic housing and going to Jaycar or similar electronics shop to look for a locally available plug that those pins would fit into. They look like a molex style pin in the photo.
Or just cut off the white plug and fit said locally available plug.
9Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Fri Feb 18, 2022 2:08 am
+1 Jaycar sell fully waterproof plug and sockets.
10Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Fri Feb 18, 2022 12:31 pm
Gaz: much research a long time ago pointed to them being a TE Connectivity product - at around AU$3.0 PER PIN!!! That's when I figured out you could punch a Molex 93-thou series into the hole, even though they're a bit of tight fit. I tried Molex 75-thou series too, but they are too small. I guess tills.de are getting them a little cheaper by buying in bulk, but that would explain the relatively high price of the K-cable. You're right - cut the buggers off and crimp something else on.
11Back to top Go down   Simple auxiliary wiring diagrams Empty Re: Simple auxiliary wiring diagrams Fri Feb 18, 2022 5:16 pm
Packo
Packo
Thanks for the replies and suggestions. For the last 2 years I have been using my own "work around" which entails using tight fitting pins into the holes in the female plug in the relay box and covered in heat shrink, I suppose they will continue their good service until perhaps TacKler puts in his next order.
______________
83 K100 HRD Outfit
1992 K1100 Outfit
1983 K100 Basic
